SPARKRU 0 Posted April 23, 2024 A clear explanation of connecting SPDIF - digital audio output from the Tinker Board. https://community.volumio.com/t/tinker-board-s-spdif-docker/9938/5 In Tinker Board, there is no way to passively output the SPDIF signal directly! The Tinker Board has a pin (SPDIF output connector) for connecting to daughter peripherals (boards) with harness and Coaxial and Optical outputs soldered on it. With the help of which, you can subsequently output a digital audio signal to your external source (amplifier, receiver, etc.). Daughter board with wiring and digital signal outputs, connected using pins on the Tinker Board - Vcc5V+, Gnd, S/Pdif. https://community.volumio.com/uploads/default/original/2X/7/736c44029b466040f89dcf61f87b6e9d92d4171e.jpeg https://community.volumio.com/t/tinker-board-s-spdif-docker/9938/5 Share this post Link to post Share on other sites
