Shin 0 Posted June 24, 2024 Hi, I am following the URL below to start up SPI with WiringPi library. I can see spidev in /dev on my TinkerBoard2S. Therefore, I believe the spi settings are reflected at boot time. linaro@linaro-alip:~/Desktop/CSampleCode/spiSpeed$ ls /dev/spidev* /dev/spidev1.0 /dev/spidev5.0 When I run the sample code, I get an error "Unble to open SPI device". Can you please tell me the cause and countermeasure? linaro@linaro-alip:~$ cd /home/linaro/Desktop/CSampleCode/spiSpeed/ linaro@linaro-alip:~/Desktop/CSampleCode/spiSpeed$ sudo ./spiSpeed +-------+--------+----------+----------+-----------+------------+ | MHz | Size | mS/Trans | TpS | Mb/Sec | Latency mS | +-------+--------+----------+----------+-----------+------------+ Unable to open SPI device: No such file or directory Board:TinkerBoard2S Linux version:4.4.194 Best regards, Share this post Link to post Share on other sites
tooz 56 Posted June 26, 2024 hello @Shin, sorry for the inconvenience. this was caused by a bug that we're aiming to fix in the next releases (for both kernel 4.19/ 5.10), before that, please follow the steps below to fix it manually. 1. update the system time (the compiler library would check it so the time has to be correct) 2. use commands to rebuild and reinstall wiringpi libraries for tinker board 2s: cd /usr/local/share/gpio_lib_c_rk3399 sudo ./build clean sudo ./build uninstall sudo ./build Share this post Link to post Share on other sites
Shin 0 Posted June 27, 2024 hello @tooz I installed WiringPi using the method you provided. However, the problem was not resolved. I have already installed the latest Linux(debian 11 v.3.0.18 kernel 5.10). linaro@linaro-alip:/usr/local/share/gpio_lib_c_rk3399$ sudo ./build clean wiringPi: [Clean] DevLib: [Clean] gpio: [Clean] Examples: [Clean] Gertboard: [Clean] PiFace: [Clean] Quick2Wire: [Clean] PiGlow: [Clean] linaro@linaro-alip:/usr/local/share/gpio_lib_c_rk3399$ sudo ./build uninstall wiringPi: [UnInstall] DevLib: [UnInstall] gpio: [UnInstall] linaro@linaro-alip:/usr/local/share/gpio_lib_c_rk3399$ sudo ./build wiringPi Build script ===================== WiringPi Library [UnInstall] Rockchip Rockchip [Compile] wiringPi.c [Compile] wiringTB.c [Compile] wiringSerial.c [Compile] wiringShift.c [Compile] piHiPri.c [Compile] piThread.c [Compile] wiringPiSPI.c [Compile] wiringPiI2C.c [Compile] softPwm.c [Compile] softTone.c [Compile] mcp23008.c [Compile] mcp23016.c [Compile] mcp23017.c [Compile] mcp23s08.c [Compile] mcp23s17.c [Compile] sr595.c [Compile] pcf8574.c [Compile] pcf8591.c [Compile] mcp3002.c [Compile] mcp3004.c [Compile] mcp4802.c [Compile] mcp3422.c [Compile] max31855.c [Compile] max5322.c [Compile] sn3218.c [Compile] drcSerial.c [Compile] wpiExtensions.c [Link (Dynamic)] [Install Headers] [Install Dynamic Lib] WiringPi Devices Library [UnInstall] [Compile] ds1302.c [Compile] maxdetect.c [Compile] piNes.c [Compile] gertboard.c [Compile] piFace.c [Compile] lcd128x64.c [Compile] lcd.c [Compile] piGlow.c [Link (Dynamic)] [Install Headers] [Install Dynamic Lib] GPIO Utility [Compile] gpio.c [Compile] readall.c [Compile] pins.c [Link] [Install] All Done. NOTE: To compile programs with wiringPi, you need to add: -lwiringPi to your compile line(s) To use the Gertboard, MaxDetect, etc. code (the devLib), you need to also add: -lwiringPiDev to your compile line(s). linaro@linaro-alip:/usr/local/share/gpio_lib_c_rk3399$ cd /home/linaro/Desktop/CSampleCode/spiSpeed/ linaro@linaro-alip:~/Desktop/CSampleCode/spiSpeed$ sudo gcc -o spiSpeed spiSpeed.c -lwiringPi -lpthread linaro@linaro-alip:~/Desktop/CSampleCode/spiSpeed$ ls /dev/spidev* /dev/spidev1.0 /dev/spidev5.0 linaro@linaro-alip:~/Desktop/CSampleCode/spiSpeed$ sudo ./spiSpeed +-------+--------+----------+----------+-----------+------------+ | MHz | Size | mS/Trans | TpS | Mb/Sec | Latency mS | +-------+--------+----------+----------+-----------+------------+ Unable to open SPI device: No such file or directory Share this post Link to post Share on other sites
tooz 56 Posted July 2, 2024 hello @Shin, 1. for kernel 5.10, please replace files in gpio_lib_c_rk3399 with https://www.asuswebstorage.com/navigate/a/#/s/3059D9ACD7AF4D849E68AB69661499C84 2. and then rebuild and install wiringpi libraries: cd /usr/local/share/gpio_lib_c_rk3399 sudo ./build clean sudo ./build uninstall sudo ./build Share this post Link to post Share on other sites
Shin 0 Posted July 2, 2024 hello @tooz Problem solved. Thank you very much. Share this post Link to post Share on other sites
