wahaha 4 Posted August 7, 2024 i was referring to rockchip's boot guide on how to boot into RK3399 here. They mentioned to follow this flow (i am using miniloader approach to SD Card): As such, I went to Asus github page to pull `rkbin`, `u-boot`, and `kernel` to build. I have successfully build the uboot with: ``` ./make.sh tinker_board_2 CROSS_COMPILE=aarch64-linux-gnu- ``` -> which generates uboot.img, trust.img and rk3399_loader_v1.30.128.bin. I then created the IDBLoader image with: ``` tools/mkimage -n rk3399 -T rksd -d /home/rkbin/bin/rk33/rk3399_ddr_800MHz_v1.30.bin idbloader.img cat /home/rkbin/bin/rk33/rk3399_miniloader_v1.30.bin >> idbloader.img ``` Kernel is straightforward as per the other posts: ``` make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- tinker_board_2_defconfig make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- rk3399-tinker_board_2.img -j16 ``` After that I created rootfs with this guide. So I have all the required images: idbloader.img, uboot.img, trust.img, boot.img, rootfs.img. However, when I put them all together based on rockchip's docs, I am still not able to boot into screen. Any ideas what is wrong? I don't think it's even getting into the boot section because there is no green light once I put power in. Share this post Link to post Share on other sites
tooz 56 Posted August 8, 2024 hello @wahaha, from what you've decribed it's likely that the board isn't booting to either first loader or uboot. please be sure that the idbloader is located in 0x64 instead of 0x40 dd if=$IMAGES/idbloader.bin of=$DEVICE seek=64 conv=nocreat Share this post Link to post Share on other sites
wahaha 4 Posted August 8, 2024 Hey @tooz, Am I correct that the partition should be like this? # Create a new partition table and partitions sudo parted -s /dev/sdb mklabel gpt # Primary GPT and MBR partitions are implicit in GPT and need not be created separately sudo parted /dev/sdb unit s mkpart idbloader 64 7167 # loader1 (PartNum in GPT: 1) sudo parted /dev/sdb unit s mkpart uboot 16384 24575 # loader2 (PartNum in GPT: 2) sudo parted /dev/sdb unit s mkpart trust 24576 32767 # trust (PartNum in GPT: 3) sudo parted /dev/sdb unit s mkpart boot 32768 262143 # boot (PartNum in GPT: 4) sudo parted /dev/sdb set 4 boot on sudo parted /dev/sdb unit s mkpart rootfs ext4 262144 16777182 # rootfs (PartNum in GPT: 5) sudo parted /dev/sdb print followed by: sudo dd if=idbloader.img of=/dev/sdb1 status=progress sudo dd if=uboot.img of=/dev/sdb2 status=progress sudo dd if=trust.img of=/dev/sdb3 status=progress sudo dd if=boot.img of=/dev/sdb4 status=progress sudo dd if=rootfs.img of=/dev/sdb5 status=progress sync Share this post Link to post Share on other sites
wahaha 4 Posted August 8, 2024 @tooz, can you confirm if i actually need `idbloader.img`? correct me if i'm wrong, but it seems like `idbloader.img` has been packed together with `uboot.img` when i run `make tinker_board_2_defconfig` -> which generates uboot.img and trust.img If that's the case, which partition / sector should be be `dd` into? Share this post Link to post Share on other sites
tooz 56 Posted August 15, 2024 hello @wahaha, in short: yes. idbloader is different from uboot, and you will need to dd dbloader in order to boot into uboot idbloader will need to be located in seek 0x64 in emmc whether the individual partition exists or not Share this post Link to post Share on other sites
wahaha 4 Posted August 17, 2024 (edited) @tooz, okay, last question for this topic - is the below method correct in creating the idbloader.img? ``` tools/mkimage -n rk3399 -T rksd -d /home/rkbin/bin/rk33/rk3399_ddr_800MHz_v1.30.bin idbloader.img cat /home/rkbin/bin/rk33/rk3399_miniloader_v1.30.bin >> idbloader.img ``` This was from the rockchip site i linked at the start of the thread. If i'm wrong, how is idbloader.img created please? Edited August 17, 2024 by wahaha Share this post Link to post Share on other sites
tooz 56 Posted August 19, 2024 hello @wahaha, On 8/17/2024 at 6:29 PM, wahaha said: tools/mkimage -n rk3399 -T rksd -d /home/rkbin/bin/rk33/rk3399_ddr_800MHz_v1.30.bin idbloader.img cat /home/rkbin/bin/rk33/rk3399_miniloader_v1.30.bin >> idbloader.img the commands are correct, for the actual ddr bin and miniloader bin used for the project, please refer to rkboot/rk3399miniall.ini https://github.com/TinkerBoard/rockchip-linux-rkbin/blob/linux4.19-rk3399-debian10/RKBOOT/RK3399MINIALL.ini Share this post Link to post Share on other sites
