wahaha 4 Posted August 26, 2024 I am trying to view the uboot and boot messages on the tinkerboard 2s as it boots up, but it is failing to print out the message to computer terminal (via screen). I have connected the cables to gpio pins 6, 8, 10. (gnd, uart0_tx, uart0_rx) as per image below. from there, i plug it into the computer and used the below code to get the usb device that it is connected to sudo dmesg | grep tty Result : [21875.686247] cdc_acm 1-4:1.0: ttyACM0: USB ACM device From there, I used: sudo screen /dev/ttyACM0 115200` to launch screen with baud rate of 115200.. But there is no output on the screen. Not sure what is wrong? is Uart enabled by default? Share this post Link to post Share on other sites
tooz 56 Posted August 27, 2024 hello @wahaha, please add the overlay to /boot/config.txt, save and reboot and see if the overlay comes effective sudo vi /boot/config.txt overlay=console-uart0-overlay Share this post Link to post Share on other sites
