ryo 0 Posted September 5, 2024 Hello, I am trying to burn DebianOS into TinkerBoard3S(not Tinker3). I connected the Tinker to my Windows Laptop(Windows11) with a USB-MicroB cable as described in the instructions in this manual(https://tinker-board.asus.com/download/E22692_Tinker_Board_3_UM_WEB.pdf), but the Laptop does not recognize it.(Also, it is not recognized as a target by balenaEtcher). ・Current Status The Red LED on the back is on. When I connected the 3S via USB to Laptop, the device is listed as “unknown device” in the device manager of the windows Laptop. I tried the following, but the results were the same. ・Replace the USB cable. ・Change the USB port(of laptop) ・Connecting to other windows laptop ・Update and Reboot Windows. Is there anything else I need to do regarding the setup? Share this post Link to post Share on other sites
tooz 56 Posted September 5, 2024 hello @ryo, have you adjusted the dip switches to 1 and 2 so the board is in emmc mode? (on the other hand if you set them to 'on', it would be in sd card mode) Share this post Link to post Share on other sites
ryo 0 Posted September 6, 2024 Thank you so much for your kind message and help. I tried with both dip switches turned off as shown in the picture, but the result was the same. Is there anything else I should check? Anyway, I burn the OS to the SD card. I succeed to run OS from the SD card. I am not sure that it shows the recognition result of the emmc, but the results of "fdisk -l" is below: linaro@linaro-alip:~$ sudo fdisk -l Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/mmcblk0: 14.56 GiB, 15634268160 bytes, 30535680 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/mmcblk1: 28.82 GiB, 30945574912 bytes, 60440576 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: 73987B6B-4974-4C94-A3E8-58AB2EB7A946 Device Start End Sectors Size Type /dev/mmcblk1p1 16384 24575 8192 4M unknown /dev/mmcblk1p2 24576 32767 8192 4M unknown /dev/mmcblk1p3 32768 163839 131072 64M unknown /dev/mmcblk1p4 163840 294911 131072 64M unknown /dev/mmcblk1p5 294912 360447 65536 32M unknown /dev/mmcblk1p6 360448 393215 32768 16M unknown /dev/mmcblk1p7 393216 524287 131072 64M unknown /dev/mmcblk1p8 524288 60440511 59916224 28.6G unknown The size of SD card is 32GB. I also attached the screenshot of the desktop. I would like to note that, we have not recognize the tinker from the windows laptop yet. Best regards, Share this post Link to post Share on other sites
tooz 56 Posted September 6, 2024 hello @ryo, since you have sd image ready, you can flash tinker board 3's emmc in ums mode. please keep the sd card in the board and 1. switch all the dip switches to off 2. connect tinker board 3 and laptop with micro usb cable 3. power on, open device manager and see if the board is recognised as 'ASUS Tinker UMS USB Device' 4. use balena etcher to flash it Share this post Link to post Share on other sites
ryo 0 Posted September 9, 2024 hello @tooz, Thank you so much for your kind message and help. I was able to burn the OS using the method you answered. Thank you so much for your prompt response. Best regards, Share this post Link to post Share on other sites
