deanmsands3 0 Posted December 5, 2024 I'd like to have my Tinker 2S boot with a Plymouth animation to hide the boot-up messages. I have a Plymouth theme I created on an x64 host and I'd like to use it on my Tinker. If Plymouth isn't an option, is there an alternative? Share this post Link to post Share on other sites
tooz 56 Posted December 6, 2024 hello @deanmsands3, you will have to download the sources and re-compile the boot image in order to replace boot logo: https://github.com/TinkerBoard/TinkerBoard/wiki/Developer-Guide#changing-the-boot-logo Share this post Link to post Share on other sites
deanmsands3 0 Posted December 6, 2024 The TinkerBoard boot logo? It's much simpler (for the Tinker 2/S). Just convert a 24-bit BMP (less than 700kb) and dd it to the splash partition. But I was hoping to hide the boot messages with a service like Plymouth. (5 hours later) And I found it. 1. Set the default Plymouth theme sudo update-alternatives --install /usr/share/plymouth/themes/default.plymouth default.plymouth /usr/share/plymouth/themes/spinner/spinner.plymouth 100 2. Update initramfs sudo initramfs -u 3. Mount the "boot" partition sudo mount /dev/mmcblk1p8 /boot 4. Append "console=tty0 quiet splash plymouth.ignore-serial-consoles" to /boot/cmdline.txt echo "console=tty0 quiet splash plymouth.ignore-serial-consoles" | sudo tee -a /boot/cmdline.txt 5. Reboot sudo reboot Share this post Link to post Share on other sites
tooz 56 Posted December 9, 2024 hello @deanmsands3, thank you for letting us know & updating the solution Share this post Link to post Share on other sites
