Jump to content
Sign in to follow this
Fu-.
GPIO2C6 and GPIO2C7 voltages are lower than else
Recommended Posts
Question about GPIO2C6 and GPIO2C7 pins.
It is possible to set them to GPIO using wiringPi, but the voltage at HIGH output is lower than other GPIO pins. It is only about 1.95V.
Upon further investigation, I found that a clock-like waveform is output during HIGH output.
GPIO2C6 is exclusive with SPI5_CLK and GPIO2C7 is exclusive with SPI5_CSN, but it appears that the SPI5 clock continues to be output when each pin is set as a GPIO.
Any suggestions?
Share this post
Link to post
Share on other sites
hello @Fu-.,
setting spi is not supported in wiringpi
what are you setting for gpio2c6 and gpio2c7 and what's your configuration?
Share this post
Link to post
hello @tooz
I'm setting both pins as GPIO.
I don't want these pin as using SPI, just only GPIO.
Edited by Fu-.
Share this post
Link to post
hello @Fu-.,
from what you decribed it's possible that it might be a hardware issue, but i'm not 100% sure.
have you also modified the settings of /boot/config.txt ?
Share this post
Link to post
hello @tooz
Yes, I've changed /boot/config.txt
Before:
#intf:spi5=off
After:
intf:spi5=off
gpioall says GPIO2C6 and C7 are GPIO, also I can control the signals HIGH,and LOW.
When signal is HIGH, the voltage is lower than other GPIO pins. It is only about 1.95V.
Moreover, I 've confirmed that the waveform was going up and down like an SPI clock even though it was holding HIGH.
I wonder why signal is oscllating?
and why the voltage is too low?
Share this post
Link to post
heloo @Fu-.,
looks they're in spi mode. to further investigate the issue:
1. which version of the os are you using?
2. is tinker board 2s connected to other peripherals/ components?
Share this post
Link to post
hello @tooz
1.Tinker_Board_2-Debian-Bullseye-v3.0.20-20240527
2.No.
A notice point:
I checked I/O status with io command.
io -4 0xff77e008
ff77e008:  00000000     both pins are GPIO.
io -4 0xff760334
ff760334:  0000e233    clk_spi5_src_en is set, seems to disable SPI clock
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
