zener 0 Posted October 28, 2020 I'm trying to boot from the micro sd card, but it boots from the eMMC indepentent upon the position of the maskrom jumper. In maskrom mode: U-Boot SPL 2018.11-armbian (Feb 08 2019 - 11:55:53 +0100) Returning to boot ROM... U-Boot 2018.11-armbian (Feb 08 2019 - 11:55:53 +0100) Model: Tinker-RK3288 DRAM: 2 GiB PC event = 0x20 usb connected to SDP, force enter ums mode rk3288_maskrom_ctrl: enable_emmc = 1 usb_current_limit_ctrl: unlock_current = 1 MMC: dwmmc@ff0c0000: 1, dwmmc@ff0f0000: 0 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial Out: serial Err: serial Model: Tinker-RK3288 Net: eth0: ethernet@ff290000 UMS: LUN 0, dev 0, hwpart 0, sector 0x0, count 0x1d5a000 \wait for usb get descriptor cmd timeout rk3288_maskrom_ctrl: enable_emmc = 0 usb_current_limit_ctrl: unlock_current = 0 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3158 bytes read in 1 ms (3 MiB/s) No jumper: U-Boot SPL 2018.11-armbian (Feb 08 2019 - 11:55:53 +0100) Returning to boot ROM... U-Boot 2018.11-armbian (Feb 08 2019 - 11:55:53 +0100) Model: Tinker-RK3288 DRAM: 2 GiB PC event = 0x20 usb connected to SDP, force enter ums mode rk3288_maskrom_ctrl: enable_emmc = 1 usb_current_limit_ctrl: unlock_current = 1 MMC: dwmmc@ff0c0000: 1, dwmmc@ff0f0000: 0 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial Out: serial Err: serial Model: Tinker-RK3288 Net: eth0: ethernet@ff290000 UMS: LUN 0, dev 0, hwpart 0, sector 0x0, count 0x1d5a000 \wait for usb get descriptor cmd timeout rk3288_maskrom_ctrl: enable_emmc = 0 usb_current_limit_ctrl: unlock_current = 0 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3158 bytes read in 1 ms (3 MiB/s) Is this because there is not boot.env file as indicated? Where is u-boot located? Is it starting at the first sector of the eMMC? The currently installed u-boot appears to look for /boot/boot.env on the first parition? When is the jumper sampled? Thanks! Share this post Link to post Share on other sites
Frank_Chiang 2 Posted January 8, 2021 Hi Zener, Maybe you should connect micro usb directly to power transformers to avoid booting into UMS mode. Apart from this, what is the version of the Tinker Board image? In the uart log of the release version Tinker_Board-Debian-Stretch-V2.1.16-20200813: MMC: dwmmc@ff0c0000: 1, dwmmc@ff0f0000: 0 Test MMC(0)... *** Warning - bad CRC, using default environment There is no information about boot.env and boot.scr, but still can boot into kernel normally. Thanks and best regards, Frank. 1 Share this post Link to post Share on other sites
Olivia 0 Posted April 20, 2021 I can't understand your question, can you kindly inbox me. 1 Share this post Link to post Share on other sites
