2020 0 Posted December 2, 2020 Hello all, This Linux OS is based on Armbian_20.11_Tinkerboard_bullseye_current_5.8.18 image. I have created this OS to be able to watch Netflix via a browser. This OS is compatible with TB & TB/s. Key features: OS: Debian 11 bullseye Kernel: armv7l Linux 5.8.18-rockchip CPU: ARMv7 rev 1 (v7l) @ 4x 1.8GHz GPU: Mali T760 (Panfrost driver, OpenGL 2.1) Browser: vivaldi-stable_3.4.2066.106-1_armhf (widevine-flash) This Linux OS image is provided AS IS with NO WARRANTY and NO END USER SUPPORT. You can now download the VinVin-OS version 20201130, here ... https://www.asuswebstorage.com/navigate/a/#/s/6DFEC785172445E3A17A086BEFBFF7DAY Share code: ASUSMYFKLUXMY user: vinvin password: vin=20 Tips: Use a fast Micro SD card, minimum 3 amps power supply and a case which includes a cooling fan to avoid system crashing due to overheating. Getting Started: Write the zip compressed image with Etcher and (TB) insert SD card into a slot or (TB/s) use a USB cable to connect to your computer. Power the board: TB (First) boot takes up to two to minutes. (Second) boot takes up to one minute. Login with the user id: vinvin TB/s Remove the USB cable connected to your computer. (First) boot takes up to one to minute. Login with the user id: vinvin. Also important: resize your file system with, for example, GParted to the full capacity. Enjoy :-) Share this post Link to post Share on other sites
