Mauricio Lucas 0 Posted January 6, 2021 (edited) Hello, I try to run the lib mfrc522 python (for RFID reader), but it's just the Raspberry card. I changed the lib to use Asus.GPIO, but it doesn't work with spiV2. Does the Asus tinker have any libs or modifications that I can use with the RFID-RC522 reader? Edited January 6, 2021 by Mauricio Lucas Share this post Link to post Share on other sites
tooz 54 Posted January 7, 2021 17 hours ago, Mauricio Lucas said: Hello, I try to run the lib mfrc522 python (for RFID reader), but it's just the Raspberry card. I changed the lib to use Asus.GPIO, but it doesn't work with spiV2. Does the Asus tinker have any libs or modifications that I can use with the RFID-RC522 reader? Hello @Mauricio Lucas could you tell us how you set up the device? perhaps we can troubleshoot by going through your steps/ error logs, thank you. Share this post Link to post Share on other sites
