Pirate 3 Posted April 21, 2021 Hi, Ive upgraded from the Tinkerboard S to the Tinkerboard 2S My I2C 7 Segment 7 Digit Display doesnt work I plugged the wires in my 2S the same way as I did for the Tinkerboard S. However, I am unable to detect any I2C pluugged in. Ive enabled all the I2C options in tinker-config. root@Harbormaster:/home/linaro/Adafruit_LEDBackpack# sudo i2cdetect -y 1 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- Share this post Link to post Share on other sites
Pirate 3 Posted April 21, 2021 I have solved this one after hours of hacking away! It seems in TinkeBoard 2/2S, the I2C bus has been changed from 1, to 6 So, in any I2C controlling code, make sure you change bus from 1 (Tinkerboard) to 6 (Tinkerboard 2) root@linaro-alip:/home/linaro/Adafruit_LEDBackpack# sudo i2cdetect -y 6 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: 70 -- -- -- -- -- -- -- Share this post Link to post Share on other sites
Pirate 3 Posted April 22, 2021 Here is document showing now Pins 3/5 -> I2C bus 6 Pins 27/28 -> I2C bus 7 1 Share this post Link to post Share on other sites
Albertortor00 0 Posted May 11, 2022 Hi, i tryed to connect lcd 2004 20columns, and 4 rows, and i cant detect any device plug on the tinker 2s, can you helpe with something? I tryed with command sudo i2cdetect -y 1 sudo i2cdetect -y 2 And the others to 9, but on mi /dev/ directory, doesn't exist 6, or 7... (like you say on your post) Thank you for sure! Share this post Link to post Share on other sites
yi-hsin_hung 3 Posted May 12, 2022 @Albertortor00 Please reference following information. Thank a lot! sudo i2cdetect -y 1 sudo i2cdetect -y 2 --> Tinker Board 2S should use the following command for i2c 6 and 7 sudo i2cdetect -y 6 sudo i2cdetect -y 7 And the others to 9, but on mi /dev/ directory, doesn't exist 6, or 7... (like you say on your post) --> Could you help to reference the following information to enable i2c 6 and 7 https://github.com/TinkerBoard/TinkerBoard/wiki/Developer-Guide#tinker-board-2-on-debian-os WiringPi C library for Debian (Tinker Board 2S) I2C WiringPi for C library for Debian Firstly, modify the /boot/config.txt file as following and then reboot to enable I2C6 (wiringPi only support 1 I2C interface). ##### Hardware Interface Config ##### ## Note: uart4 and spi1 are the same pins. Set the latter one while both on. ## intf:fiq_debugger=on #intf:uart0=off #intf:uart4=off intf:i2c6=on #intf:i2c7=off #intf:i2s0=off #intf:spdif=off #intf:spi1=off #intf:spi5=off #intf:pwm0=off #intf:pwm1=off #intf:pwm3a=off #intf:test_clkout2=off Share this post Link to post Share on other sites
