sohonomura2020 0 Posted November 26, 2021 Dear Sirs I'm now connecting the IMX219 camera to tinker board 2s board. I can see the camera image now but I cannot configure the Field of View nor size. I can just see the image of center portion, very narrow FoV. I could configure the camera with media-ctl command when operating it on "tinker board". It would be great if you tell me the way to configure the camera (size, FoV, mirror/flip, etc.) with the reference scripts or sample code. Similar way to "tinker board" will be fine. I appreciate your kind help in advance. sohonomura2020 Share this post Link to post Share on other sites
sohonomura2020 0 Posted November 26, 2021 Dear Sirs I found the Capture_Test.sh in the Test_tool directory shown on Desktop. By using this script, I could see the Full FoV image. I'd like to know how to switch to binning mode to get full FoV smaller image of higher frame rate. Thank you very much for your kind help in advance. Best Regards, sohonomura2020 Share this post Link to post Share on other sites
sohonomura2020 0 Posted November 26, 2021 One more question, please. I cannot find the IQ tuning file and just run plane gst-launch-1.0 can get dark image. I can see better image when running Capture_Test.sh in Desktop directory. I'd like to know how to apply the IQ tuning file. (I remember the xml file is called in the gst-launch command line in tinker board case.) Best Regards, NOMURA Share this post Link to post Share on other sites
sohonomura2020 0 Posted November 26, 2021 Dear Sirs I found I can get brighter image if I create /tmp/flicker_mode file, but it seems the AE function does not work. Do you have any suggestion to activate the camera ISP function other than demosaic? Best Regards, sohonomura2020 Share this post Link to post Share on other sites
sohonomura2020 0 Posted November 27, 2021 Dear Sirs The reason I thought the AE didn't work is maybe the lower light condition for AE set maximum exposure condition (shutter/gain). Under the sun light condition, I can confirm the AE does work. I apologize for the confusion caused by the inadequate investigation. Now I would like to know how to set 2x2 binning mode of 30fps streaming. Best Regards, sohonomura2020 Share this post Link to post Share on other sites
tooz 56 Posted November 29, 2021 Hello @sohonomura2020, On 11/27/2021 at 9:34 AM, sohonomura2020 said: Now I would like to know how to set 2x2 binning mode of 30fps streaming. the driver has to be modified in order to support this feature, and we don't have a schedule for this yet Share this post Link to post Share on other sites
sohonomura2020 0 Posted December 10, 2021 Thank you for the reply. I understood current driver does not support this mode. however, the driver layer should be the same as the one for tinker board(RK3288), then I hope it will be available soon. By the way, when I run the gstreamer script modified from Capture_Test.sh, I experienced the instability of the camera, stopped and reboot. We just clean installed the OS and run Capture_Test.sh and see this symptom. Do you have any report about the symptom? I appreciate your kind help in advance. Bests Regards, sohonomura2020 Share this post Link to post Share on other sites
kenta 0 Posted June 21, 2022 On 11/26/2021 at 4:16 PM, sohonomura2020 said: I can see the camera image now but I cannot configure the Field of View nor size. I can just see the image of center portion, very narrow FoV. I am also facing the same issue. I'm connecting the IMX219 camera (3840x2160) to tinker board 2s board. But "v4l2-ctl --list-formats-ext" command displays only 1920x1080 resolutions. ioctl: VIDIOC_ENUM_FMT Type: Video Capture Multiplanar [0]: 'YUYV' (YUYV 4:2:2) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [1]: '422P' (Planar YVU 4:2:2) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [2]: 'NV16' (Y/CbCr 4:2:2) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [3]: 'NV61' (Y/CrCb 4:2:2) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [4]: 'YM16' (Planar YUV 4:2:2 (N-C)) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [5]: 'NV21' (Y/CrCb 4:2:0) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [6]: 'NV12' (Y/CbCr 4:2:0) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [7]: 'NM21' (Y/CrCb 4:2:0 (N-C)) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [8]: 'NM12' (Y/CbCr 4:2:0 (N-C)) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [9]: 'YU12' (Planar YUV 4:2:0) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [10]: 'YM24' (Planar YUV 4:4:4 (N-C)) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [11]: 'RGGB' (8-bit Bayer RGRG/GBGB) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [12]: 'GRBG' (8-bit Bayer GRGR/BGBG) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [13]: 'GBRG' (8-bit Bayer GBGB/RGRG) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [14]: 'BA81' (8-bit Bayer BGBG/GRGR) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [15]: 'RG10' (10-bit Bayer RGRG/GBGB) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [16]: 'BA10' (10-bit Bayer GRGR/BGBG) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [17]: 'GB10' (10-bit Bayer GBGB/RGRG) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [18]: 'BG10' (10-bit Bayer BGBG/GRGR) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [19]: 'RG12' (12-bit Bayer RGRG/GBGB) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [20]: 'BA12' (12-bit Bayer GRGR/BGBG) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [21]: 'GB12' (12-bit Bayer GBGB/RGRG) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [22]: 'BG12' (12-bit Bayer BGBG/GRGR) Size: Stepwise 32x16 - 1920x1080 with step 8/8 [23]: 'RGB3' (24-bit RGB 8-8-8) Size: Stepwise 32x16 - 1920x1080 with step 8/8 With "media-ctl -p" command, the board seems to recognize the IMX219 correctly. Media controller API version 0.1.0 Media device information ------------------------ driver rkisp1 model rkisp1 serial bus info hw revision 0x0 driver version 0.0.0 Device topology - entity 1: rkisp1-isp-subdev (4 pads, 6 links) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev0 pad0: Sink [fmt:SRGGB10_1X10/1920x1080 field:none crop.bounds:(0,0)/1920x1080 crop:(0,0)/1920x1080] <- "rkisp1_dmapath":0 [] <- "rockchip-mipi-dphy-rx":1 [ENABLED] pad1: Sink <- "rkisp1-input-params":0 [ENABLED] pad2: Source [fmt:YUYV8_2X8/1920x1080 field:none crop.bounds:(0,0)/1920x1080 crop:(0,0)/1920x1080] -> "rkisp1_selfpath":0 [ENABLED] -> "rkisp1_mainpath":0 [ENABLED] pad3: Source -> "rkisp1-statistics":0 [ENABLED] - entity 2: rkisp1_mainpath (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video0 pad0: Sink <- "rkisp1-isp-subdev":2 [ENABLED] - entity 3: rkisp1_selfpath (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video1 pad0: Sink <- "rkisp1-isp-subdev":2 [ENABLED] - entity 4: rkisp1_dmapath (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video2 pad0: Source -> "rkisp1-isp-subdev":0 [] - entity 5: rkisp1-statistics (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video3 pad0: Sink <- "rkisp1-isp-subdev":3 [ENABLED] - entity 6: rkisp1-input-params (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video4 pad0: Source -> "rkisp1-isp-subdev":1 [ENABLED] - entity 7: rockchip-mipi-dphy-rx (2 pads, 2 links) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev1 pad0: Sink [fmt:SRGGB10_1X10/1920x1080@10000/300000 field:none] <- "m00_b_imx219 1-0010":0 [ENABLED] pad1: Source [fmt:SRGGB10_1X10/1920x1080@10000/300000 field:none] -> "rkisp1-isp-subdev":0 [ENABLED] - entity 8: m00_b_imx219 1-0010 (1 pad, 1 link) type V4L2 subdev subtype Sensor flags 0 device node name /dev/v4l-subdev2 pad0: Source [fmt:SRGGB10_1X10/1920x1080@10000/300000 field:none] -> "rockchip-mipi-dphy-rx":0 [ENABLED] I appreciate your kind help in advance. And, I cannot find the Test_tool directory. Could you give any information about the Capture_Test.sh ? On 11/26/2021 at 5:16 PM, sohonomura2020 said: Capture_Test.sh in the Test_tool directory shown on Desktop Best regards, Kenta Share this post Link to post Share on other sites
tooz 56 Posted June 22, 2022 hello @kenta, the default sensor settings of IMX219 is 1920x1080, the cmds below can be used to adjust IMX219 sensor settings to 3280x2464: media-ctl -d /dev/media0 --set-v4l2 '"rkisp1-isp-subdev":0[fmt:SRGGB10_1X10/3280x2464]' media-ctl -d /dev/media0 --set-v4l2 '"rkisp1-isp-subdev":0[crop:(0,0)/3280x2464]' media-ctl -d /dev/media0 --set-v4l2 '"rkisp1-isp-subdev":2[fmt:YUYV8_2X8/3280x2464]' media-ctl -d /dev/media0 --set-v4l2 '"rkisp1-isp-subdev":2[crop:(0,0)/3280x2464]' media-ctl -d /dev/media0 --set-v4l2 '"m00_b_imx219 1-0010":0[fmt:SRGGB10_1X10/3280x2464]' v4l2-ctl -d /dev/video0 --set-fmt-video=width=3280,height=2464,pixelformat=NV12 --set-crop=top=0,left=0,width=3280,height=2464 And, I cannot find the Test_tool directory. Could you give any information about the Capture_Test.sh the script can be downloaded here: https://www.asuswebstorage.com/navigate/a/#/s/5B06BC29115E4004A181738E5E0F909E4 Share this post Link to post Share on other sites
Lucas32 0 Posted May 21, 2023 Hello there, I am currently facing a similar issue where I am connecting the IMX219 camera (3840x2160 resolution) to a Tinker Board 2S. However, when using the "v4l2-ctl --list-formats-ext" command, I only observe resolutions limited to 1920x1080 being displayed. On the other hand, when I utilize the "media-ctl -p" command, it appears that the board correctly recognizes the IMX219 camera. The output reveals the media device information, device topology, and entities involved in the media pipeline. I sincerely appreciate any assistance you can provide to resolve this matter. Regards Devid Lucas Share this post Link to post Share on other sites
tooz 56 Posted May 22, 2023 hello @Lucas32, 8 hours ago, Lucas32 said: I am currently facing a similar issue where I am connecting the IMX219 camera (3840x2160 resolution) to a Tinker Board 2S. However, when using the "v4l2-ctl --list-formats-ext" command, I only observe resolutions limited to 1920x1080 being displayed. the sensor setting for imx219 is 1920x1080 by default, you can change it to 3840x2160 with commands: media-ctl -d /dev/media0 --set-v4l2 '"rkisp1-isp-subdev":0[fmt:SRGGB10_1X10/3840x2160]' media-ctl -d /dev/media0 --set-v4l2 '"rkisp1-isp-subdev":0[crop:(0,0)/3840x2160]' media-ctl -d /dev/media0 --set-v4l2 '"rkisp1-isp-subdev":2[fmt:YUYV8_2X8/3840x2160]' media-ctl -d /dev/media0 --set-v4l2 '"rkisp1-isp-subdev":2[crop:(0,0)/3840x2160]' media-ctl -d /dev/media0 --set-v4l2 '"m00_b_imx219 1-0010":0[fmt:SRGGB10_1X10/3840x2160]' v4l2-ctl -d /dev/video0 --set-fmt-video=width=3840,height=2160,pixelformat=NV12 --set-crop=top=0,left=0,width=3840,height=2160 Share this post Link to post Share on other sites
