Jump to content
Tinker Board
[Release] Tinker Edge R Debian 10 V2.0.5
Recommended Posts
TinkerOS default username is "linaro", password is "linaro"
Release Notes:
1. Merge Rockchip release rk3399pro_linux_release_v1.4.1_20201203
2. RKNNAPI: API: 1.7.1 (566a9b6 build: 2021-10-28 14:56:17)
3. RKNNAPI: DRV: 1.6.0 (159d2d3 build: 2021-01-12 15:23:09)
4. Upgrade to Debian 10
5. Upgrade Wi-Fi driver to v5.12.1.8-2-g58609677a.20210923_COEX20210504-2323
6. Wi-Fi: Disable P2P
7. Fine tune USB type C
8. Modem: supported automatically connecting and SIM detection
9. Fine tune modem manager
10. Upgrade modemmanager to v1.14.12
11. gst-rkmpp: Update packages to disable mpeg2 decoder
12. HDMI: Support HDMI panel VGG804826, VGG804838 and DWE2100
13. Support flag to disable UMS mode
14. Enable saveenv on MMC devices.
15. Modify saveenv based on boot up device.
16. mmc: assign right mmc card for rk_vendor_storage (This resolves the rebooting aging failure.)
Open-Source Code:
https://github.com/TinkerEdgeR
SHA256:
c5ccd489174e0472cfc14f95f76cab7aeb1e5e05dc1322793de2fb0c1dd33d59 (zip)
Download link: https://dlcdnets.asus.com/pub/ASUS/mb/Embedded_IPC/Tinker_Edge_R/Tinker_Edge_R-Debian-Buster-v2.0.5-20220217.zip
Others: https://tinker-board.asus.com/download-list.html
Share this post
Link to post
Share on other sites
How to flash img to ROM?
Both command line tools (included in Debian Stretch v1.0.1 zip) on linux and Windows GUI tool failed. Also, I checked Debian Stretch v1.0.1 (and v1.0.4) img can be flashed in both ways.
Share this post
Link to post
Are there instructions for writing this new Tinker_Edge_R-Debian-Buster-v2.0.5-20220217.img file to the Tinker Board Edge R?
It doesn't seem to work in the same way as the older images with the Windows GUI or the CLI tools.  Both tools seems to reject the image file as a valid image to write to the Edge R.
From my examination of the older image files compared with this image file, it appears this image doesn't have the required bootloaders prepended to the image.
Share this post
Link to post
Nevermind.  I got it working.  I needed to follow the steps below:
  • install a previous version of Debian for the Tinker Board Edge R (ie. v1.0.4)
  • connect the Edge R to my PC via a USBC cable
  • reboot the Edge R into UMS mode
  • finally, use balenaEtcher to write the v2.0.5 image from my PC
Share this post
Link to post
I have installed v2.0.5 image to Tinker Edge R, but Wifi is not available and Bluetooth returns to Off after reboot.  A few questions:
1. Should WiFi work out-the-box after imaging?
2.Do I need to download driver separately for Wifi?
Here are some logs:
# ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.189  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::87f:835f:43bf:81eb  prefixlen 64  scopeid 0x20<link>
        ether 24:4b:fe:56:00:1f  txqueuelen 1000  (Ethernet)
        RX packets 4950  bytes 4665354 (4.4 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 2300  bytes 438743 (428.4 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 24
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Local Loopback)
        RX packets 16  bytes 1072 (1.0 KiB)
        TX packets 16  bytes 1072 (1.0 KiB)
# nmcli con show
NAME                UUID                                  TYPE      DEVICE
Wired connection 1  aexxx166-xxx-34d5-xxxx-ec2xxxx6829a  ethernet  eth0
# lsmod
Module                  Size  Used by
bcmdhd               1228800  0
Thanks in advance.
Share this post
Link to post
Hi MThompson,
I have tried to follow your suggestion.
first, i have installed succesfully Tinker Edge R Debian V1.0.1 into the board. then whilst the board is connected to laptop via a USBC cable, i executed the command ''sudo reboot ums'' in the linux terminal on the tinker edge r.
 I can find the tinker edge r in the device manager but cannot find it in the balena etcher when selecting the target.
Do you have any suggestion?
thank you in advance
Share this post
Link to post
hello @BillyAma,
1. yes - if you have the wifi module iserted, you can use it staight away
2. no need as long as you're using one of the modules from the qvl
Share this post
Link to post
hello @marco@bigsis.tech,
1. connect tinker edge r to the computer
2. shutdown tinker edge r
3. repower tinker edge r so it can be switched to ums mode
4. use tools such as balena etcher to flash
  • Like 1
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
