tugsynz 0 Posted June 23, 2022 I have tried flashing with latest debian image and latest flash tool boot it into flash mode with jumper connected. All I get is "flash has failed" Usb shows up as "Class for rockusb devices" "Rockusb Device" Any help would be appreciated Share this post Link to post Share on other sites
marco@bigsis.tech 0 Posted January 9, 2023 Hi, I am having the same issue, did you manage to solve it? Share this post Link to post Share on other sites
saeed soleimanifar 0 Posted April 26, 2023 Hi, I am having same problem as well does any body solve this? Share this post Link to post Share on other sites
tooz 53 Posted April 27, 2023 if you see 'flash has failed' you will need to remove the jumper and try reflash again Share this post Link to post Share on other sites
saeed soleimanifar 0 Posted April 29, 2023 On 4/27/2023 at 11:42 AM, tooz said: if you see 'flash has failed' you will need to remove the jumper and try reflash again I tired this many times I see board is in mask mode but when flash.sh tries to write data I see "prepare IDB failed" error. Share this post Link to post Share on other sites
