oussama 0 Posted September 6, 2022 I am working on an object detection project and I need to change the operating system of the tinker edge T which is Mendel to another linux operating system, I tried with an SD card and it didn't work, I want to know if it is possible to change it and how? Share this post Link to post Share on other sites
tooz 56 Posted September 7, 2022 hello @oussama, apart from having a sd card with os image loaded, please make sure the board enables boot from sd card -- there are four switches on the back of the board and the sd card boot mode is: on, off, on, on. if you'd like to boot from emmc, it is on, off, off, off. for more details: https://tinker-board.asus.com/doc_et.html#Flashing_the_Tinker_Edge_T more about mendel os: https://coral.ai/software/#mendel-linux Share this post Link to post Share on other sites
gavin67890 0 Posted November 6, 2023 Hi @oussama, I've been investigating BalenaOS on a Coral Dev Board (very similar to the Tinker Edge T). Perhaps it might fit your needs? Being built by Balena – the people who built Etcher – it comes with a flash image creator. I had a look an there is an image. If you give it a try, I'd be interested to know how you get on an compare notes. Share this post Link to post Share on other sites
