kwakPro 0 Posted October 26, 2022 I need help. I have a Tinker Board S R2. I want to use UART with Android 11 OS. Is this possible? In some information, Tinker Board 2 use UART with Android OS by "Mraa library for android". But, I want use it with Tinker Board S R2. Please, give me a answer. Thanks. Share this post Link to post Share on other sites
tooz 56 Posted October 26, 2022 hello @kwakPro, yes, you can use 40 pin uart with mraa library for android on android os, for your reference: Developer Guide · TinkerBoard/TinkerBoard Wiki · GitHub Share this post Link to post Share on other sites
kwakPro 0 Posted October 27, 2022 (edited) Thank you for the answer. But, In "UART_Test_SOP.pdf" file, 1. Config the /dtoverlay/config.txt by adb commands. Thinker Board S R2 was not working that command 'adb pull /dtoverlay/config.txt'. It is not exist file. How can I solve it? Thanks. Edited October 27, 2022 by kwakPro Share this post Link to post Share on other sites
tooz 56 Posted November 3, 2022 hello @kwakPro did you first: adb root adb remount adb pull /dtoverlay/config.txt (edit) and then adb push config.txt /dtoverlay/ ? Share this post Link to post Share on other sites
kwakPro 0 Posted November 4, 2022 hello @tooz Thank you for answer. I did it. but adb pull /dtoverlay/config.txt at this command, response is "No such file or directory" so I check the file by adb shell There is no file like config.txt My Device is Tinker Board S R2, Android OS Version is "Tinker_Board_2-Android11-v2.0.6-20220303.img" (I think Tinker board 2 Series have that file..) I need your help. How can i use UART1..? Thanks. Share this post Link to post Share on other sites
denchakapon 5 Posted November 5, 2022 On 11/3/2022 at 1:02 PM, tooz said: hello @kwakPro did you first: adb root adb remount adb pull /dtoverlay/config.txt (edit) and then adb push config.txt /dtoverlay/ ? /dtoverlay/config.txt does not exist in Android 11 v1.0.0 Tinkerboard S R2.0 release. There are only cmdline.txt file and overlays folder: WW_Tinker_Board:/dtoverlay $ ls -la total 24 drwxrwxrwx 3 root root 16384 2021-12-14 01:16 . drwxr-xr-x 25 root root 4096 2021-12-14 00:43 .. -rwxrwxrwx 1 root root 58 2021-12-14 00:46 cmdline.txt drwxrwxrwx 2 root root 2048 2021-12-14 00:46 overlays WW_Tinker_Board:/dtoverlay $ 1 Share this post Link to post Share on other sites
kwakPro 0 Posted November 15, 2022 @denchakapon Thank you for answer. So do you know that how can i use uart GPIO port?? Share this post Link to post Share on other sites
