Francois 0 Posted November 19, 2022 Hi, Trying to reflash my Tinker Edge T - but running into a problem when running "sudo reboot-bootloader." It occurs at step 4 in the below steps to reflash. 1. Flash the sdcard_arm64.img file to your microSD card with a program such as balenaEtcher. 2. Change the boot mode switches to boot from SD card. (ON: Switch 1/Switch 3/Switch 4; OFF: Switch 2) 3. Insert the SD card and then power on the board and the board should auto boot. 4. Please launch weston-terminal on the board and run sudo reboot-bootloader to reboot the board into the fastboot mode. (Error at this step : Could not find a misc partition! Giving up. ) 5. Run the flash.cmd script for Windows or flash.sh for Linux in this directory. Share this post Link to post Share on other sites
tooz 55 Posted November 21, 2022 hello @Francois, On 11/19/2022 at 10:47 PM, Francois said: 4. Please launch weston-terminal on the board and run sudo reboot-bootloader to reboot the board into the fastboot mode. (Error at this step : Could not find a misc partition! Giving up. ) what reboot-bootloader does is to look for partable misc partition, please make sure there's a misc partition for booting Share this post Link to post Share on other sites
Francois 0 Posted November 21, 2022 Perfect! Thanks - managed to flash my board again ? Share this post Link to post Share on other sites
