dmitrich 0 Posted January 11, 2023 After some time of continuous working (after 2 days, some time after week), the audio output from jack 3.5 starts hissing, noise (shhhhhhh) . Whether it's a youtube video in the browser, or it's my mp3 playlist playing. Only reboot can help. I use the Tinker Board Debian 10 V3.0.11 image on my Tinker board R2.0. I use it as an audio player through jack 3.5. Before R2.0 I used a regular Tinker board and did not face this problem. Has anyone encountered a similar problem, what could be the matter? Share this post Link to post Share on other sites
tooz 56 Posted January 13, 2023 hello @dmitrich, while we try reproduce the issue, is it ok if we check the pulse log? what is the output when you execute this line? sudo cat /var/log/syslog* | grep -i pulse Share this post Link to post Share on other sites
Remontoir 0 Posted January 16, 2023 We do have exactly the same issue: while using the jack output, some (we have dozen of then in the wild ) Tinkerboard S R.20 are randomly and suddenly (can be hours or days) outputing a white noise sound. We are also using the last TinkerOS linux release (based on debian 10.10). When the problem arises, there is absolutely nothing in the logs. When using a digital output ( either bluetooth or HDMI ) there's no such problem. Maybe a problem related to the DAC ? Share this post Link to post Share on other sites
serkanp 0 Posted March 1, 2023 did you solved this problem? we are also facing same thing and we have lots of device.. Share this post Link to post Share on other sites
c0rnelius 0 Posted March 5, 2023 Is there a plan to resolve this issue or give us any insight into why this is happening or are you leaving this up to the Scooby-Doo gang? Share this post Link to post Share on other sites
serkanp 0 Posted March 9, 2023 for those who still suffering from this problem.. asus send us audio firmware and we are testing it.. and i am sharing it with all you guys.. :)) attached file contains the firmware.. and here are the steps came from asus R&D department: Please follow the steps to check the FW version for reference. a. Unzip and copy the file to Tinker Board b. cd ALC4030U-FW-Tool sudo chmod a+x ./rt_UAC_utility sudo ./rt_UAC_utility --status sudo ./rt_UAC_utility --force 0x49F6_ALC4030U_ASUS_Tinker_Board_0x0BDA_V13_20220718.rfw --reset RST_2_ATTACH sudo ./rt_UAC_utility --status --reset RST_2_ATTACH sudo reboot sudo ./rt_UAC_utility –status => using this command to check the driver FW version. ALC4030U-FW-Tool.zip Share this post Link to post Share on other sites
dmitrich 0 Posted March 9, 2023 did you solved this problem? no but there is some news, need to try: https://github.com/TinkerBoard/debian_kernel/issues/68#issuecomment-1461710354 Share this post Link to post Share on other sites
serkanp 0 Posted March 10, 2023 19 hours ago, dmitrich said: did you solved this problem? no but there is some news, need to try: https://github.com/TinkerBoard/debian_kernel/issues/68#issuecomment-1461710354 that is also me bro :)) i both write here and there... this solves the problem Share this post Link to post Share on other sites
