Mortis1369 0 Posted February 21, 2023 I have no idea how active this community is, but I chose the Tinker Board 2s as a platform for one of my projects. The github repo link is dead. I managed to find a fork that was functional, but it isn't complete. Is there some other source where I can draw all of the files necessary (minus the source code for AOSP as I already have it) in order to begin developing my operating system for this board? Or should I just resort to brute force and make a blob? Share this post Link to post Share on other sites
tooz 56 Posted February 22, 2023 hello @Mortis1369, sorry about the inconvenience, will check with team and get back to you shortly. are you developing an android 11 based os? Tinker Board 2 - Android (github.com) Share this post Link to post Share on other sites
Mortis1369 0 Posted February 22, 2023 To start with, yes. Share this post Link to post Share on other sites
lloydhussell 0 Posted October 23, 2023 This may have been the problem. Share this post Link to post Share on other sites
MarciS 0 Posted January 4, 2024 Hello all, is there a reference page with build instruction? I just found the reference page with the download instruction here manifest . Nevertheless, I couldn't find any guide with a procedure that describes it. Share this post Link to post Share on other sites
tooz 56 Posted January 5, 2024 hello @MarciS, the build instruction for tinker board 2s: https://github.com/TinkerBoard/TinkerBoard/wiki/Tinker-Board-2-&-2S#21-build-image there are quite a lot of versions so be sure to use the right one when you do repo init -u (manifest) -b -m 1 Share this post Link to post Share on other sites
MarciS 0 Posted January 14, 2024 Hello, thank you for the feedback. The link was very useful, nevertheless I had some issues when building u-boot and the kernel (for the moment I tests these). For u-boot I get Error: arch/arm/dts/.rk3036-sdk.dtb.pre.tmp:77.1-10 syntax error FATAL ERROR: Unable to parse input tree make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3036-sdk.dtb] Error 1 make[2]: *** Waiting for unfinished jobs.... Error: arch/arm/dts/.rk3368-px5-evb.dtb.pre.tmp:335.1-10 syntax error FATAL ERROR: Unable to parse input tree make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3368-px5-evb.dtb] Error 1 Error: arch/arm/dts/.rk3328-evb.dtb.pre.tmp:301.1-10 syntax error FATAL ERROR: Unable to parse input tree make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3328-evb.dtb] Error 1 Error: arch/arm/dts/.rk3368-sheep.dtb.pre.tmp:288.1-10 syntax error FATAL ERROR: Unable to parse input tree make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3368-sheep.dtb] Error 1 arch/arm/dts/rk3126-evb.dtb: Warning (reg_format): "reg" property in /syscon@20008000/usb2-phy@17c has invalid length (8 bytes) (#address-cells == 2, #size-cells == 1) arch/arm/dts/rk3126-evb.dtb: Warning (avoid_default_addr_size): Relying on default #address-cells value for /syscon@20008000/usb2-phy@17c arch/arm/dts/rk3126-evb.dtb: Warning (avoid_default_addr_size): Relying on default #size-cells value for /syscon@20008000/usb2-phy@17c arch/arm/dts/rk3128-evb.dtb: Warning (reg_format): "reg" property in /syscon@20008000/usb2-phy@17c has invalid length (8 bytes) (#address-cells == 2, #size-cells == 1) arch/arm/dts/rk3128-evb.dtb: Warning (avoid_default_addr_size): Relying on default #address-cells value for /syscon@20008000/usb2-phy@17c arch/arm/dts/rk3128-evb.dtb: Warning (avoid_default_addr_size): Relying on default #size-cells value for /syscon@20008000/usb2-phy@17c Error: arch/arm/dts/.rk3188-radxarock.dtb.pre.tmp:383.1-10 syntax error FATAL ERROR: Unable to parse input tree make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3188-radxarock.dtb] Error 1 Error: arch/arm/dts/.rk3368-geekbox.dtb.pre.tmp:320.1-10 syntax error FATAL ERROR: Unable to parse input tree make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3368-geekbox.dtb] Error 1 Error: arch/arm/dts/.rk3368-lion.dtb.pre.tmp:196.1-10 syntax error FATAL ERROR: Unable to parse input tree make[2]: *** [scripts/Makefile.lib:319: arch/arm/dts/rk3368-lion.dtb] Error 1 make[1]: *** [dts/Makefile:101: arch-dtbs] Error 2 make: *** [Makefile:882: dts/dt.dtb] Error 2 Build uboot failed! ms@c64416174e4e:/source$ ls u-boot/: I fixed it modifying the Makefile in /source/u-boot/arch/arm/dts so that only mk3399 is listed. New content of /source/u-boot/arch/arm/dts/Makefile ... dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3399-evb.dtb \ rk3399-firefly.dtb \ rk3399-puma-ddr1333.dtb \ rk3399-puma-ddr1600.dtb \ rk3399-puma-ddr1866.dtb dtb-$(CONFIG_ARCH_MESON) += \ ... This allowed me to discard all other board and build only for rk3399. @tooz Do you know if this may cause future issue or it can be accepted? About the kernel instead: I was never able to build the kernel with clang. I got the error: ms@92fa117c0cc6:/source$ ./build.sh -C will build kernel with Clang -------------------KERNEL_DTS:rk3399-tinker-board-2 Start build kernel CLEAN . CLEAN certs CLEAN drivers/scsi CLEAN fs/unicode CLEAN kernel CLEAN lib CLEAN net/wireless CLEAN security/selinux CLEAN usr CLEAN .tmp_versions #### build completed successfully (8 seconds) #### /bin/sh: 1: ../prebuilts/clang/host/linux-x86/clang-r383902b/bin/clang: not found HOSTCC scripts/basic/fixdep /bin/sh: 1: ../prebuilts/clang/host/linux-x86/clang-r383902b/bin/clang: not found HOSTCC scripts/kconfig/conf.o YACC scripts/kconfig/zconf.tab.c LEX scripts/kconfig/zconf.lex.c HOSTCC scripts/kconfig/zconf.tab.o HOSTLD scripts/kconfig/conf ./scripts/gcc-version.sh: 26: ../prebuilts/clang/host/linux-x86/clang-r383902b/bin/clang: not found ./scripts/gcc-version.sh: 27: ../prebuilts/clang/host/linux-x86/clang-r383902b/bin/clang: not found ./scripts/gcc-version.sh: 29: ../prebuilts/clang/host/linux-x86/clang-r383902b/bin/clang: not found ./scripts/gcc-version.sh: 26: ../prebuilts/clang/host/linux-x86/clang-r383902b/bin/clang: not found ./scripts/gcc-version.sh: 27: ../prebuilts/clang/host/linux-x86/clang-r383902b/bin/clang: not found ./scripts/gcc-version.sh: 29: ../prebuilts/clang/host/linux-x86/clang-r383902b/bin/clang: not found init/Kconfig:17: syntax error init/Kconfig:16: invalid option ./scripts/clang-version.sh: 15: ../prebuilts/clang/host/linux-x86/clang-r383902b/bin/clang: not found ./scripts/gcc-plugin.sh: 11: ../prebuilts/clang/host/linux-x86/clang-r383902b/bin/clang: not found make[2]: *** [scripts/kconfig/Makefile:104: tinker_board_2_defconfig] Error 1 make[1]: *** [Makefile:578: tinker_board_2_defconfig] Error 2 make: *** [Makefile:286: __build_one_by_one] Error 2 #### failed to build some targets (2 seconds) #### Build kernel failed! @tooz Do you know a fix? Building the kernel with $ ./build.sh -K return the following error make[4]: *** No rule to make target 'drivers/media/i2c/cam_sensor/cam_sensor.o', needed by 'drivers/media/i2c/cam_sensor/built-in.a'. Stop. make[3]: *** [scripts/Makefile.build:637: drivers/media/i2c/cam_sensor] Error 2 make[2]: *** [scripts/Makefile.build:637: drivers/media/i2c] Error 2 make[1]: *** [scripts/Makefile.build:637: drivers/media] Error 2 I checked in the folders and no objects for cam_imx219.c, cam_ov5647.c, cam_sensor_code.c are present in the folder. It is like they are not compiled at all so they cannot be added during the build process. I've also tried to use only one job to build but nothing changed. The only thing I've found to have the kernel compilation working was by changing the file kernel/drivers/media/i2c/cam_sensor/Makefile with the content: #cam_sensor-objs := \ # cam_sensor_core.o \ # cam_imx219.o \ # cam_ov5647.o cam_sensor_objs := #obj-$(CONFIG_VIDEO_CAM_SENSOR) += cam_sensor.o obj-$(CONFIG_VIDEO_CAN_SENSOR) += Nevertheless this means that no camera sensor are added at all. @tooz do you know if this is due to the missing step with clang? Do you know if there is a way to fix it? Thank you! Share this post Link to post Share on other sites
tooz 56 Posted January 16, 2024 hello @MarciS, what are the commands you used for downloading source codes/ compiling? are you using the codebase from: https://github.com/TinkerBoard2-Android/kernel/tree/android11-rk3399/drivers/media/i2c/cam_sensor ? cam_imx219.c, cam_ov5647.c, cam_sensor_code.c are only available in android 11 Share this post Link to post Share on other sites
MarciS 0 Posted February 12, 2024 Hell @tooz, to download I used $ repo init -u https://github.com/TinkerBoard2-Android/manifest.git -b android11-rk3399 -m tinker_board_2-android11-2.0.1.xml $ repo sync and to build I used the these instruction from 2.1 Build image source build/envsetup.sh lunch WW_Tinker_Board_2-userdebug ./build.sh -UKAu Note that I removed the option C build kernel with Clang because it was failing and I wasn't able to fix it. Share this post Link to post Share on other sites
tooz 56 Posted February 16, 2024 hello @MarciS, ./build.sh -UCKAu not working is not an expected result, what is your build environment? Share this post Link to post Share on other sites
