Jump to content
Sign in to follow this
Subbu
I2S DAC for TB 2 S
Recommended Posts
Hi
I purchased a TB 2S 4GB version as it was some how cheaper than even TB R2.0 or TB 2S 2GB!!! Maybe a mistake from the seller in his listing.  I got it to make a streamer for my audio system.
Anyways, with Tinker OS I managed to install Logitech Media Server and Squeezelite on it. Also got my NAS to be mounted automatically on TB 2 S. I use my old iFi USB DAC to play my music. Excellent output. But the DAC is somehow playing foul with one channel. Drops out at time.
I want to try a I2S DAC on TB 2S. I am a newbie to SBC and related stuff.
  • Are all HAT DACs I2S DAC?
  • With the huge heatsink, it is not possible to connect any HAT DAC. What terminal of TB 2 S do I use to connect with point to point connection to a DAC?
  • Do I do any configuration on TB 2 S?
  • Would I need to install any driver for any generic HAT DACs?
 Thanks
Subbu
Share this post
Link to post
Share on other sites
hello @Subbu,
→it varies. not all HAT DACs i2s DAC, tinker-40pin-i2s is one of the methods for using DAC
→ it depends on the circuit design of the DAC you're using. we'd also suggest you to use perhaps 2 or 3 pieces of extansion headers(the heatsink is tall) in case you connect to the wrong pins
→different DACs all have different hardware design and chips, their dts files should be configured and enabled. using one of the DACs from the QVL (Tinker Board (asus.com)) would be a good way to avoid most of the compatibility issues.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
