sathish 0 Posted April 21, 2023 Hi, where should I find the dhcpcd.conf file on tinker board r2.0. I saw /etc/dhcp/dhclient.conf this is different from below. In raspberry pi it is available on /etc/dhcpcd.conf we can use this file to change IP on raspberry pi easily. Share this post Link to post Share on other sites
tooz 56 Posted April 21, 2023 hello @sathish, it is not built in the tinker os, if you'd like to use dhcpcd: sudo apt-get install dhcpcd5 the dhcpcd.con will be locaed in /etc/ alternatively, you can use nmcli con mod to configure the ip network 1 Share this post Link to post Share on other sites
sathish 0 Posted April 24, 2023 On 4/21/2023 at 6:41 PM, tooz said: hello @sathish, it is not built in the tinker os, if you'd like to use dhcpcd: sudo apt-get install dhcpcd5 the dhcpcd.con will be locaed in /etc/ alternatively, you can use nmcli con mod to configure the ip network Hi tooz, Thanks for your information as per instruction dhcpcd.conf file appeared in /etc after installing through the above command. But I am trying to change IP through dhcpcd.conf like raspberry Pi Eg. interface eth0 inform 192.168.1.240 static routers=192.168.1.1 static domain_name_servers=8.8.8.8 4.2.2.2 noipv6 But above method not reflecting on asus tinker board r2.0. Share this post Link to post Share on other sites
sathish 0 Posted April 26, 2023 Now above format is working fine for me. The only thing is I'm trying to copy this file through ftp(filezilla) & scp (through python script) but I cant copy files its showing access denied. Copy only working on home directory. On 4/24/2023 at 11:20 AM, sathish said: Hi tooz, Thanks for your information as per instruction dhcpcd.conf file appeared in /etc after installing through the above command. But I am trying to change IP through dhcpcd.conf like raspberry Pi Eg. interface eth0 inform 192.168.1.240 static routers=192.168.1.1 static domain_name_servers=8.8.8.8 4.2.2.2 noipv6 But above method not reflecting on asus tinker board r2.0. Share this post Link to post Share on other sites
