Jump to content
hisataro
How to write OS image without PC
Recommended Posts
Currently, we use "balenaEtcher" to write Android OS images by connecting to a PC.
Is there a way to write an image from a USB or SD card without connecting a PC?
Share this post
Link to post
Share on other sites
hello @hisataro,
you can burn a SD card with Debian OS, save the Android OS (.img) file into the card, and use dd command to write the Android image from SD card to emmc:
  1. Download Debian OS from Tinker Board website --  the latest version is Tinker Board 2 /2S Debian 11 (kernel 5.10) v3.0.6
  2. Use BalenaEtcher to flash the Debian OS to a SD card, please make sure the flashing is sucessful and Tinker Board 2S is bootable with the image
  3. Download and save Android OS into the same SD card that has Debian OS in it – you don’t need to use BalenaEtcher for this step, just save the Android OS as file
  4. Insert the SD card into the Tinker Board 2S you’d like to flash Android OS onto, and boot the device from SD card
  5. Once the device is boot up, use dd command to write the Android OS into device’s emmc:
sudo dd bs=4M if=/path/to/TinkerOSAndroid.img of=/dev/mmcblk0
  1. To verify, power off the device and remove the SD card, and boot the device from emmc, the expected result is that Tinker Board 2S boots from emmc with Android OS.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
