Jump to content
Jovan
[Debian 11 - 3.0.11][TinkerBoard 2S] How the change baudrate of uart0 / ttyS0
Recommended Posts
Hello,
When. in /boot/config.txt I enable uart0 and uart4 and define them with different baud rates, both are always initialized with 1500000 baudrate.
intf:fiq_debugger=on
intf:uart0=on
intf:uart4=on
#intf:i2c6=off
#intf:i2c7=off
#intf:i2s0=off
#intf:spdif=on
#intf:spi1=off
#intf:spi5=off
#intf:pwm0=off
#intf:pwm1=off
#intf:pwm3a=off
#intf:test_clkout2=off
uart0 = Serial("/dev/ttyS0", 115200)
uart4 = Serial("/dev/ttyS4", 1000000)
then after the boot I get:
linaro@linaro-alip:~$ sudo dmesg | grep tty
[    4.664967] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal  androidboot.verifiedbootstate=orange androidboot.serialno=b6977d7c12b9a2e5 root=/dev/mmcblk0p8 rw rootwait console=tty0 earlycon=uart8250,mmio32,0xff1a0000 console=ttyFIQ0 rootfstype=ext4 coherent_pool=1m
[    5.325828] printk: console [tty0] enabled
[    5.681796] Registered FIQ tty driver
[    6.876158] printk: console [ttyFIQ0] enabled
[    6.890795] Registered fiq debugger ttyFIQ0
[    7.667771] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 45, base_baud = 1500000) is a 16550A
[    7.668238] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 47, base_baud = 1500000) is a 16550A
[   14.656870] ttyFIQ ttyFIQ0: tty_port_close_start: tty->count = 1 port count = 2
How to change baudrate this?
Thanks
Share this post
Link to post
Share on other sites
hello @Jovan,
modifying /boot/config.txt only allows the function to be enabled
On 12/8/2023 at 10:17 PM, Jovan said:
linaro@linaro-alip:~$ sudo dmesg | grep tty [ 4.664967] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.verifiedbootstate=orange androidboot.serialno=b6977d7c12b9a2e5 root=/dev/mmcblk0p8 rw rootwait console=tty0 earlycon=uart8250,mmio32,0xff1a0000 console=ttyFIQ0 rootfstype=ext4 coherent_pool=1m [ 5.325828] printk: console [tty0] enabled [ 5.681796] Registered FIQ tty driver [ 6.876158] printk: console [ttyFIQ0] enabled [ 6.890795] Registered fiq debugger ttyFIQ0 [ 7.667771] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 45, base_baud = 1500000) is a 16550A [ 7.668238] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 47, base_baud = 1500000) is a 16550A [ 14.656870] ttyFIQ ttyFIQ0: tty_port_close_start: tty->count = 1 port count = 2
these are uart driver init loggings
baud rates can be changed in user space
  • Like 1
Share this post
Link to post
Yup, my question is kinda pointless... we are changing the baudrate in user space, and it's working properly.
The issue was somewhere else, not related to TinkerBoard itself (we've resolved that).
Thanks
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
