Vova Efcom 0 Posted November 4, 2024 Hi, I have the TinkeBoard 3N I am using the original Asus OS (Debian based GUI) I need the system to start up without requesting the username and password How can I do it? Thanks Share this post Link to post Share on other sites
tooz 56 Posted November 5, 2024 hello @Vova Efcom, you can edit the lightdm config to enable auto-login sudo vi /etc/lightdm/lightdm.conf uncomment these two lines and then reboot autologin-user=linaro autologin-user-timeout=0 Share this post Link to post Share on other sites
Vova Efcom 0 Posted November 5, 2024 Hi, I've tried this before, but no luck. Should I be entering the password somewhere else? I've attached a screenshot of the lightdm.conf file. Maybe I’m doing something wrong? Thanks! Share this post Link to post Share on other sites
tooz 56 Posted November 5, 2024 hello @Vova Efcom, you have edited the wrong lines, the lines that should be uncommented are line 126 & line 127 #guest-session= #session-wrapper=lightdm-session #greeter-wrapper= #guest-wrapper= #display-setup-script= #display-stopped-script= #greeter-setup-script= #session-setup-script= #session-cleanup-script= #autologin-guest=false autologin-user=linaro autologin-user-timeout=0 #autologin-in-background=false #autologin-session= #exit-on-failure=false Share this post Link to post Share on other sites
Vova Efcom 0 Posted November 5, 2024 Many thanks! It is working! Share this post Link to post Share on other sites
