Brian Van Den Beuken 0 Posted May 3, 2021 on the current spec page there's a claim that it reaches 797 Tinkerboard 2 specs thats far from the results I get of 233/234 and the orginal TB board would manage around 400 again far below what you report, so it seems the TB2 isnt' really fully using its potential. What versions of GLMark2-es2 were you using, I am building the current 2021-2 version, X11-glesv2 flavour How can I unlock this addtional GPU power you report? Share this post Link to post Share on other sites
tooz 56 Posted May 5, 2021 hello @Brian Van Den Beuken On 5/3/2021 at 8:24 PM, Brian Van Den Beuken said: What versions of GLMark2-es2 were you using the version is glmark2 201.07 these commands can be used to test the graphic performance: echo performance | tee $(find /sys/ -name *governor) su linaro -c "DISPLAY=:0.0 taskset -c 4-5 glmark2-es2 --off-screen" previous thread for your reference: https://tinkerboarding.co.uk/forum/archive/index.php/thread-939.html Share this post Link to post Share on other sites
Frank3_Wu 2 Posted May 5, 2021 also can reference this post. https://tinkerboarding.co.uk/forum/thread-3233-post-13473.html#pid13473 Quote about GLMark2, you need to check the CPU performance (or let it run at higher frequency), or test it with "--off-screen" this config to show real GPU (alone) benchmark, since if drawing on the desktop it also needs CPU to process in legacy x window. Share this post Link to post Share on other sites
