Jump to content
Pirate
No wireguard headers
Recommended Posts
Hi all,
Unable to install WireGuard on TinkerBoard 2 running 2.0.0
I've installed `linux-headers-arm64` but, wireguard doesn't seem to have the required headers in the kernel
root@Harbormaster:~# modprobe wireguard
modprobe: FATAL: Module wireguard not found in directory /lib/modules/4.4.194
root@Harbormaster:~# sudo wg-quick up wg0
[#] ip link add wg0 type wireguard
RTNETLINK answers: Operation not supported
Unable to access interface: Protocol not supported
[#] ip link delete dev wg0
Cannot find device "wg0"
root@Harbormaster:~# sudo wg show wg0
According to https://github.com/adrianmihalko/raspberrypiwireguard/issues/11 Wireguard not starting because of wrong kernel-headers
Edited by Pirate
Share this post
Link to post
Share on other sites
Can't install openvpn either. Looks like more missing modules.
root@Harbormaster:~# modprobe tun
modprobe: FATAL: Module tun not found in directory /lib/modules/4.4.194
May  6 22:27:00 Harbormaster systemd[1]: Couldn't stat device /dev/net/tun: No such file or directory
May  6 22:27:00 Harbormaster systemd[1]: openvpn@server.service: Failed with result 'exit-code'.
Edited by Pirate
Share this post
Link to post
@Frank3_Wu thanks, I was able to install the kernel header successfully
wget https://github.com/TinkerBoard2/kernel/releases/download/tinker_board_2-debian_10-2.0.0/linux-headers-4.4.194_4.4.194-1_arm64.deb
dpkg -i linux-headers-4.4.194_4.4.194-1_arm64.deb
However, it seems /boot/ doesnt have enough disk space
root@Harbormaster:~# apt-get install wireguard
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
  linux-image-5.10.0-6-cloud-arm64 linux-image-cloud-arm64
Suggested packages:
  linux-doc-5.10 debian-kernel-handbook
Recommended packages:
  firmware-linux-free apparmor
The following NEW packages will be installed:
  linux-image-5.10.0-6-cloud-arm64 linux-image-cloud-arm64 wireguard
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/16.3 MB of archives.
After this operation, 81.1 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 100742 files and directories currently installed.)
Preparing to unpack .../linux-image-5.10.0-6-cloud-arm64_5.10.28-1_arm64.deb ...
Unpacking linux-image-5.10.0-6-cloud-arm64 (5.10.28-1) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-5.10.0-6-cloud-arm64_5.10.28-1_arm64.deb (--unpack):
 cannot copy extracted data for './boot/vmlinuz-5.10.0-6-cloud-arm64' to '/boot/vmlinuz-5.10.0-6-cloud-arm64.dpkg-new': failed to write (No space left on device)
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
W: Last kernel image has been removed, so removing the default symlinks
Selecting previously unselected package linux-image-cloud-arm64.
Preparing to unpack .../linux-image-cloud-arm64_5.10.28-1_arm64.deb ...
Unpacking linux-image-cloud-arm64 (5.10.28-1) ...
Selecting previously unselected package wireguard.
Preparing to unpack .../wireguard_1.0.20210223-1_all.deb ...
Unpacking wireguard (1.0.20210223-1) ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
I checked how much space I have left and its enough
Quote
root@Harbormaster:~# df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root        15G  8.1G  5.5G  60% /
devtmpfs        972M  8.0K  972M   1% /dev
tmpfs           980M   13M  968M   2% /dev/shm
tmpfs           980M   25M  956M   3% /run
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs           980M     0  980M   0% /sys/fs/cgroup
log2ram         250M   21M  230M   9% /var/log
/dev/mmcblk1p7  4.9M  192K  4.5M   5% /boot
tmpfs           196M     0  196M   0% /run/user/998
tmpfs           196M     0  196M   0% /run/user/0
tmpfs           196M  8.0K  196M   1% /run/user/1000
Share this post
Link to post
@Frank3_Wu please consider making /boot/ partition bigger in future releases
Now I am playing with GParted, trying to resize /boot/ partition so I can install wireguard
Share this post
Link to post
tinker2_kernel_1-wire.tgz
https://asus-my.sharepoint.com/:u:/p/joe_sun/ESh3OzqpXi1GsPqlQqd2roYBY3UI6DoTd2wizrWQS6IwXw?e=7HpAnU
Hi  @Shadway:
Can you try the attachment 1-wire driver
1)  copy boot.img to tinker2
2)  sudo dd if=boot.img of=/dev/mmcblk1p4
3)  sudo vi /boot/config.txt
    add overlay=w1-gpio
4)  Reboot tinkerboard and the /sys/bus/w1/devices/w1_bus_master1 is generated.
5) GPIO0B0 (The 7th leg of 40Pin) is 1-wire Pin
Hope helps you
Joe
Share this post
Link to post
Hello.
Are there any news regarding this?
I'm trying to setup a Tinker 2S board and install OpenVPN, but the TUN/TAP module is not installed.
Share this post
Link to post
On 11/1/2021 at 9:56 AM, Joe said:
tinker2_kernel_1-wire.tgzUnavailable
Hi  @Shadway:
    add overlay=w1-gpio
Hope helps you
Joe
Hi, can you re-upload file please?
Share this post
Link to post
hello @Shadway,
joe has re-uploaded the file, let us know if you have any questions, thank you.
Share this post
Link to post
7 hours ago, tooz said:
hello @Shadway,
Hi, tooz. Unfortunately it doesn't work. The /sys/bus/w1/devices/w1_bus_master1 doesn't generated.
Share this post
Link to post
Hi Shadway:
tinker2_kernel_1-wire_20220629.zip
    add overlay=w1-gpio
4)  Reboot tinker2 and the /sys/bus/w1/devices/w1_bus_master1 is generated.
5) GPIO2B2 (The 5th Pin of 40Pin) is 1-wire Pin
Hope helps you
Share this post
Link to post
Hello, I'm trying to install openvpn but system reports it don't have tun/tap module. If is it possibility to run openvpn on this board?
Share this post
Link to post
Hello,
I am using a ThinkerBoard, Tinker OS (Tinker_Board-Debian-Buster-v3.0.11-20211026) and I have the same issue with Wireguard.
Error.
Quote
$ wg-quick up wg0
I verify that I am up to date.
Quote
sudo apt update && sudo apt upgrade
The kernel version is.
Quote
uname -r
4.4.194
Everything points to a headers issue, but I haven't found a solution.
Quote
modprobe wireguard
I search for the headers with the same kernel version (4.4.194).
Quote
apt list linux-headers-4.*
But the most similar is 4.19.*,.
What is recommended in these cases?
- Keep looking for the headers (4.4.194).
- Look for another kernel and install the headers?
I even ran a test, install a new kernel and header version.
Quote
apt-get install linux-image-4.19.0-23-armmp linux-headers-4.19.0-23-armmp
reboot
apt install --reinstall wireguard wireguard-dkms
(Its armmp version ok?)
Reinstall the app.
Quote
Looks that its installed on the new kernel version 4.19.0.23.
Setting up wireguard-dkms (1.0.20210219-1~bpo10+1) ...
Loading new wireguard-1.0.20210219 DKMS files...
It is likely that 4.4.194 belongs to a chroot's host
Building for 4.19.0-23-rt-armmp
Building initial module for 4.19.0-23-rt-armmp
Done.
wireguard.ko:
Running module version sanity check.
 - Original module
   - No original module exists within this kernel
 - Installation
   - Installing to /lib/modules/4.19.0-23-rt-armmp/updates/dkms/
depmod...
DKMS: install completed.
Setting up wireguard (1.0.20210223-1~bpo10+1) ...
But I have the same problem, it doesn't seem to recognize it. It still refers to the previous kernel.
Quote
modprobe wireguard
If anyone has an idea? :)
Regards.
Share this post
Link to post
Hello,
Searching the forum I found another similar topic, where they share the download link for the headers (linux-headers-4.4.194_4.4.194-7_armhf.deb).
Once downloaded, installed reboot, then reinstall the wireguard, reboot and run.
Quote
dpkg -i linux-headers-4.4.194_4.4.194-7_armhf.deb
reboot
Quote
reboot
Quote
wg-quick up wg0
Regards.
Share this post
Link to post
Hello. Somebody have problem to install wireguard to image Tinker Board 2 Debian 11 (kernel 5.10) v3.0.6 ?
I install linux headers to version 5.10.160 from here here.
Then i used command
dpkg -i linux-headers-5.10.160_5.10.160-1_arm64.deb
reboot
reboot
modprobe wireguard
modprobe: FATAL: Module wireguard not found in directory /lib/modules/5.10.160
After errors I try install newest kernel from repository debian and install new linux headers, but it can't solve my problem. Has anyone encountered a similar error and knows how to solve it?
Share this post
Link to post
hello @wiki11,
when you apt install wireguard wireguard-dkms
was there any dependency errors?
Share this post
Link to post
3 hours ago, tooz said:
hello @wiki11,
When I used command
I see next warning
wg-quick.target is a disabled or a static unit, not starting it.
Module build for kernel 5.10.160 was skipped since the
kernel headers for this kernel does not seem to be installed.
Module build for kernel hci_uart.ko was skipped since the
Module build for kernel rtk_btusb.ko was skipped since the
All console log from install in file.
It is before i install  linux headers
log.txt
Share this post
Link to post
hello @wiki11,
if you're using debian 11 v.3.0.6 os, please install linux-headers-5.10.110_5.10.110-2_arm64.deb:
sudo dpkg -i linux-headers-5.10.110_5.10.110-2_arm64.deb
sudo apt install -y wireguard-dkms wireguard-tools
you should be able to use wireguard after the package/ header installation and modprobe wireguard is not required
Share this post
Link to post
hello @wiki11,
Hello. Maybe you made a mistake in name of linux headers?
If i install linux-headers-5.10.110 and then install wireguard, I see next errors
Setting up dctrl-tools (2.24-3) ...
Setting up dkms (2.8.4-3) ...
Setting up wireguard-dkms (1.0.20210219-1) ...
It is likely that 5.10.160 belongs to a chroot's host
Building for 5.10.110, 5.10.160, hci_uart.ko and rtk_btusb.ko
Building initial module for 5.10.110
Error!  The /var/lib/dkms/wireguard/1.0.20210219/5.10.110/aarch64/dkms.conf for module wireguard includes a BUILD_EXCLUSIVE directive which
does not match this kernel/arch.  This indicates that it should not be built.
Skipped.
After this I reinstall system on microsd and first install  linux-headers-5.10.160 and then wireguard.  I see next errors
Building for 5.10.160, hci_uart.ko and rtk_btusb.ko
Building initial module for 5.10.160
Error!  The /var/lib/dkms/wireguard/1.0.20210219/5.10.160/aarch64/dkms.conf for module wireguard includes a BUILD_EXCLUSIVE directive which
Skipped.
Share this post
Link to post
 It is look like module wireguard not include in kernel 5.10.160,  аlthough kernel after 5.6 must have module wireguard include on base
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
