Jump to content
haxboard
Help! LAN stop working after some time
Recommended Posts
Hello folks!
I have an strange situation here.
Several devices, in different places, with different connections (4G, fiber optic, DSL, etc),  have the LAN port stopping working after some time.
I´m using the Android-V14.4.0.14.
I have more then 10 devices with this same situation, across different cities.
It´s simple stop working. Cannot ping any IP, even the local router (asus->router).
The only way to get it working again, is removing the LAN cable and put it again, or reboot the OS.
And its not the router (as I mentioned, different routers, different connections are used). And also, other devices like DVR CAM are always working.
Attached the dmesg file if someone maybe can identify something...
Anyone have an advise? It´s getting a really trouble for me that...
Thanks in advance!
Share this post
Link to post
Share on other sites
hello @haxboard,
are all your devices the same model(tinker board s)?
did this occur only after updating to android v14.4.0.14, or did it happen on other versions as well?
also, could you re-attach the logs as it's not shown on the forum, you can also inbox me the file and we can have a look
Share this post
Link to post
Hi @tooz
Thank you for your reply.
Yes, all of devices are Tinker Board S (we only use S model).
Its also happened on previous version, this is was the reason to update to v14.4.0.14 hoping that was any kind of fix on it.
This is the link for the log download: https://bit.ly/3ClmEJQ
Appreciate if you can help, I´m on the dark with this situation =(
Share this post
Link to post
Hi  haxboard,
Guess whether Router or DHCP is related
[ask]
1.  If TinkerS is set to a static IP, Is it still happen disconnected??
    Settings -> More -> Ethernet -> Ethernet Ip mode -> static
2.  Is there any other software to install?
[Please take TinkerS log]
1.  su
2.  ifconfig
3.  ps
4.  ping 8.8.8.8
5.  logcat
6.  ip a
7.  route
Please help to get the log
Thanks
Share this post
Link to post
I also have this with a Tinkerboard S. It loses the lan connection at random, sometimes after days. I have tried with static route and everything, no difference. I have googled a little and found users of other android devices complaining about the same. I have concluded that it is probably an android issue, perhaps of these old versions. Wlan is a tad slower but does not drop the connection --> serves me better.
Share this post
Link to post
Hi @Joe
This issue happens even with static IP and DNS.....
@Joe do you need the log with the issue happening? Or just the log without the issue.
Because is very difficult to get the issue on realtime...and the board runs on our customers... I´m not able to replicate it but I already saw on realtime many times...
When the issue happens, they reboot the board (and we did an automate to that, to reboot automatically). Its store that run an "self-market" ...
I´m trying to replicate it but no success yet....
@SomberTinker Do you have any other post of foruns relating this issue with Android?
As we runs "self-markets" on aways places, I´m afraid to use Wifi in case of disconnections it will not return...
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
