Jump to content
brick
Manualy dd image files to eMMC when booted from sd card.
Recommended Posts
Hi, I can not boot recovery.img from sd card and can not flash from computer.
If I prepare sd card following the instructions here, then flash.sh script gets stuck on: "< waiting for any device >" (visible in script debug mode), no usb device is found on my computer - lsusb shows nothing like Mendel or Tinker or Google device there. Multiple usb cables tested. Sd card is ok, because booting from it (sdcard_arm64.img) works well.
I'd like to flash the img files manualy from another flash drive using dd command from the shell when booted from sd card.
Please, what are the correct images and their /dev/??? targets to manualy dd images to emmc?
I expect these files to be flashed (taken from flash.sh script):
  1. sudo dd BS=4M if=u-boot.imx of=/dev/???  (should it be: mmcblk0boot0 ?)
  2. sudo reboot-bootloader
  3. sudo dd BS=4M if=partition-table-8gb.img of=/dev/???  (mmcblk0 ?)
  4. sudo reboot-bootloader
  5. // somehow erase misc partition - where it is?
  6. sudo dd BS=4M if=home.img of=/dev/???   (rest of mmcblk0 ?)
  7. sudo dd BS=4M if=boot_arm64.img of=/dev/???    (should it be: mmcblk0boot1 ?)
  8. sudo dd BS=4M if=rootfs_arm64.img of=/dev/???  (should it be: mmcblk0rpmb ?)
Problems:
  • sudo reboot-bootloader gives me an error: can not find misc partition.
  • sudo dd BS=4M if=u-boot.imx of=/dev/mmcblk0 works fine, but of=/dev/mmcblk0boot0 ends with an error: operation not permited.
I appreciate any help with this.
Share this post
Link to post
Share on other sites
I've found some mapping:
  • partition-table-8gb.img -> mmcblk0 (new /dev/mmcblk0p1-4 devices are created)
  • u-boot.imx -> mmcblk0p1
  • boot_arm64.img -> mmcblk0p2
  • rootfs_arm64.img -> mmcblk0p3
  • home.img -> mmcblk0p4
After this mapping the reboot-bootloader works and the Tinker Edge T splash screen is shown and it gets stuck there. But lsusb shows me: Bus 003 Device 013: ID 0b05:7771 ASUSTek Computer, Inc. USB download gadget.
The flash.sh script still waits for any device to be connected.
What is wrong here?
Edited by brick
Share this post
Link to post
After swithing to boot from eMMC it finally boots until the error root file system not found.
Share this post
Link to post
Update:
I did an 8GB empty image on my computer and then I did dd in following order. There are captions for partitions after ther first partition-table-8gb.img is put to it.
  • boot_arm64.img -> mmcblk0p1
  • /misc is created -> mmcblk0p2
  • home.img -> mmcblk0p3
  • rootfs_arm64.img -> mmcblk0p4
I think, that this should work, but after boot the rootfs is not found and boot process stops there. I have no clue how to continue.
Edited by brick
Share this post
Link to post
Hello,
I am facing the same problem.
Is there any update or informations from anybody ?
Thanks !
Share this post
Link to post
hello @Henri / @brick,
sudo dd BS=4M if=u-boot.imx of=/dev/mmcblk0boot0
sudo dd BS=4M if=partition-table-8gb.img of=/dev/mmcblk0
sudo dd BS=4M if=boot_arm64.img of=/dev/mmcblk0p1
sudo dd BS=4M if=home.img of=/dev/mmcblk0p3
sudo dd BS=4M if=rootfs_arm64.img of=/dev/mmcblk0p4
the partition table of tinker edge t:
mmcblk0boot0 4M u-boot
mmcblk0      179:0    0  7.3G  0 disk
├─mmcblk0p1  128M boot
├─mmcblk0p2  1M misc
├─mmcblk0p3  2G home
└─mmcblk0p4  5.1G rootfs
u-boot.imx -> mmcblk0boot0
Share this post
Link to post
Hi @brick, @Henri, @tooz,
do you have some news about this topic? Do you have some fork of the armbian? Do you have discord channel for this, like Armbian has?
Best Regards.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
