Jump to content
Poko-san
How to use I2S
Recommended Posts
[Debian10 V.2.0.3]
Hello,
I want to connect to Audio DAC(Texas Instruments PCM5102A) via I2S, and want to play sound.
Normally, "aplay -l" command shows only HDMI audio device.
I edited config.txt -> intf:i2s0=on
but this didn't make any sense.
Next, I found
/boot/overlays/hifiberry-dacplus-overlay.* files,
I added config.txt -> overlay=hifiberry-dacplus-overlay
but "aplay -l" command said "no soundcards found...".
Please tell me what to do.
Thanks!
Share this post
Link to post
Share on other sites
Seconded. The overlay seems to disable HDMI sound as well, and doesn't seem to do anything..
Share this post
Link to post
The hifiberry-dacplus-overlay explicitly disables HDMI audio. This is present in /boot/overlays/hifiberry-dacplus-overlay.dts .. To answer my own question.
Also, the hifiberry-dacplus-overlay is meant for the PCM512x instead of the PCM510x . These IC's very similar, but the PCM512x series has an I2C interface, which is probed during boot.. dmesg reveals a lot of these:
[    6.163192] snd-rpi-hifiberry-dacplus sound-ext-card: ASoC: CODEC DAI pcm512x-hifi not registered
Could be this driver doesn't support the old 510x ?
Share this post
Link to post
Hello, have you managed to figure it out?
Want to connect pcm5102a to a tinker board 2 too. Is it possible currently ? Should I use any overlays ?
Share this post
Link to post
hello @Poko-san, @earx, and @giseleznev,
here's a table of compatible DACs and AMPs tested on tinker board s / r2.0 and tinker board 2s:
Brand
Model
Overlay
Tinker Board S / R2.0
Tinker Board 2S
Chip
OS
Tinker Board R2.0 Debian 10 V3.0.11 or later
Tinker Board 2 Debian 10 V2.1.6 or later
HiFiBerry
HiFiBerry DAC+ STANDARD – RCA VERSION
hifiberry-dacplus
OPA165x
HiFiBerry AMP+
hifiberry-amp
TAS5713
HiFiBerry Digi+ Standard
hifiberry-digi
WM8804
HiFiBerry DAC
hifiberry-dac
PCM5102A
HiFiBerry DAC+
hifiberry-dacplus
PCM5102A
HiFiBerry DAC+ Light
hifiberry-dac
PCM5122
HiFiBerry DAC+ PRO
hifiberry-dacplus
PCM5122
JustBoom
JustBoom Amp HAT
justboom-dac
TAS5756M
JustBoom DAC HAT
justboom-dac
PCM5122
JustBoom DAC Zero
justboom-dac
PCM5121
JustBoom Digi Zero
justboom-digi
WM8804GEDS
JustBoom Digi HAT
justboom-digi
WM8804GEDS
IQAudIO
IQaudIO Pi-Digi+
iqaudio-digi-wm8804-audio
WM8804
IQaudIO Pi-DigiAMP+
iqaudio-dacplus
TAS5756
IQaudio Pi-DAC Pro
iqaudio-dacplus
PCM5242
Share this post
Link to post
@tooz
Since I am a Linux beginner, I don't understand how overlays work etc.
I would like you to tell me in detail
how to set it to recognize the HiFiBerry DAC, for example.
I tried various things such as editing the "/boot/config.txt" file with reference to the Raspberry Pi article,
but "rkhdmidpsound" is displayed even if I run the "aplay -l" command.
Also, in my environment, there is only hifiberry-dacplus in /boot/overlays, and other overlays such as hifiberry-dac cannot be found.
Does this require installation?
Share this post
Link to post
hello @Poko-san,
i've made a simple tutorial video:
(in this video, i use 'justboom dac hat', but not all dac hats are compatible, please check before use)
prerequisites:
-tinker board 2s
-a dac that's compatible with tinker board 2s
steps:
1. check the supported dtb with command
$ ls /boot/overlays/
2. edit overlay with command (last line of the .txt, in this example it's overlay=justboom-dac)
$ sudo vim /boot/config.txt
3. save the modified .txt esc+shift+: wq
4. turn off tinker board 2s
5. insert the dac
6. power on tinker board 2s
7. check if the dac is recognized with command
$ aplay -l
8. use volume control to adjust volume, there's a build in media player, in this example i've downloaded and used rhythmbox ( https://debian.org/Rhythmbox )
please note:
1. check the compatibility before use
2. the 40-pin gpio header gets damaged very easily with unnecessary ic contacts, please be very careful when connecting the dac to tinker board 2s
Share this post
Link to post
Brand
Model
Overlay
Tinker Board 2S
Chip
OS
HiFiBerry
hifiberry-dacplus
OPA165x
HiFiBerry AMP+
hifiberry-amp
TAS5713
hifiberry-digi
WM8804
HiFiBerry DAC
hifiberry-dac
PCM5102A
HiFiBerry DAC+
hifiberry-dacplus
PCM5102A
hifiberry-dac
PCM5122
HiFiBerry DAC+ PRO
hifiberry-dacplus
PCM5122
JustBoom
JustBoom Amp HAT
justboom-dac
TAS5756M
JustBoom DAC HAT
justboom-dac
PCM5122
JustBoom DAC Zero
justboom-dac
PCM5121
JustBoom Digi Zero
justboom-digi
WM8804GEDS
JustBoom Digi HAT
justboom-digi
WM8804GEDS
IQAudIO
IQaudIO Pi-Digi+
WM8804
IQaudIO Pi-DigiAMP+
iqaudio-dacplus
TAS5756
IQaudio Pi-DAC Pro
iqaudio-dacplus
PCM5242
hi, and what about tinker board2 support. Have you tested it ? Do tinker s snd tinker 2 have any differences regarding audio.
Share this post
Link to post
Hello there,
As a Linux beginner, I find it challenging to comprehend the functioning of overlays and similar concepts. I would greatly appreciate a detailed explanation of how to configure the system to recognize specific hardware, such as the HiFiBerry DAC.
I have attempted various approaches, including editing the "/boot/config.txt" file based on the guidance provided in the Raspberry Pi article. However, when I execute the "aplay -l" command, it still displays "rkhdmidpsound" instead of the desired configuration.
Additionally, I have noticed that in my environment, only the "hifiberry-dacplus" overlay is available in the "/boot/overlays" directory, and other overlays like "hifiberry-dac" are nowhere to be found. Is it necessary to install additional components or packages to access these missing overlays?
Share this post
Link to post
hello @Lucas32,
this guide from toradex explains what device tree overlays are and how they work: https://developer.toradex.com/linux-bsp/os-development/build-yocto/device-tree-overlays-linux/
reboot is needed after you
what is the os version? the dtbo of dac hats in the qualified vendor list are already built out/ included in the os. you might want to an os that's later than v.2.1.6
Description
Tinker OS default username is "linaro", password is "linaro".
Release Notes:
* Changelog
1. First Kernel 4.19.x release version
2. Merged kernel security patch
3. Audio: Support JustBoom DAC HAT/Digi HAT/Amp HAT
4. Audio: Support IQaudIO Pi-DAC+/Pi-DAC Pro/Pi-Digi+
5. Audio: Support HiFiBerry DAC+ Light/Digi+
6. USB: Enable USB printer in kernel config
7. Config: Default enable GPIO PIN37 as S/PDIF, for Type-C DP audio function.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
