RichUK 0 Posted March 29, 2022 As the topic suggests, How do you root the Tinkerboard 2, either Andoroid 10 or 11 will do.. ? Is this forum dead? the activity is so low? Share this post Link to post Share on other sites
tooz 56 Posted May 4, 2022 hello @RichUK, you can root the device using Magisk, here's a brief instruction: -- 1. Prepare boot image -- you can either: a. Get the latest boot image from Tinker Board website: Tinker Board (asus.com) or b. build boot image from source code: Tinker Board 2 - Android · GitHub 2. Copy the boot image to your device adb push boot.img /storage/emulated/0/Download/ 3. Download the latest version of Magisk: Installation | Magisk (topjohnwu.github.io) 4. Install Magisk adb install Magisk.apk 5. Launch Magisk from your device 6. Press the Install button 7. Choose “Select and Patch a File” in method, and select the boot.img file, The Magisk app will patch the boot.img file to [Internal Storage]/Download/magisk_patched_[random_strings].img 8. Pull magisk_patched_[random_strings].img to your PC adb pull /storage/emulated/0/Download/magisk_patched_[random_strings].img 9. Flash boot image patched by magisk in fastboot mode adb reboot-bootloader fastboot flash boot magisk_patched_[random_strings].img fastboot reboot -- 1 Share this post Link to post Share on other sites
hisataro 0 Posted May 27, 2022 Magisk fails, is the procedure wrong? Unzip Tinker_Board_2-Android11-v2.0.6-20220303.zip Renamed Tinker_Board_2-Android11-v2.0.6-20220303.img to boot.img. Magisk> Magisk Install> Select Patch a File> boot.img> Let's Go fails. It is the execution result of Magisk. -Device Platform: arm64-v8a -Installing: 24.3 (243000) --Copying image to cache --Unpacking boot image ! Unable to unpacl boot image ! Installation failed Share this post Link to post Share on other sites
tooz 56 Posted May 27, 2022 hello @hisataro instead of "tinker board 2 android11 v2.0.6-20220303.img", please use the actual boot.img it can be downloaded here: https://www.asuswebstorage.com/navigate/a/#/s/FB8E093B5DCC48EA90ED5FEDEAC5DFD94 Share this post Link to post Share on other sites
hisataro 0 Posted May 30, 2022 Thank you for your support. The boot.img you sent us was successfully patched. https://tinker-board.asus.com/forum/index.php?/topic/15098-how-to-root-android-on-tinkerboard-2/&tab=comments I'm following the steps in > 9. Flash boot image patched by magisk in fastboot mode > > adb reboot-bootloader > > fastboot flash boot magisk_patched_ [random_strings] .img > > fastboot reboot I ran "fast boot flash boot", but it said "Waiting for device" and couldn't proceed. The device was recognized as "Android download gadget" from the PC, so I tried to apply the following driver, but I could not install it. https://developer.android.com/studio/run/win-usb?hl=ja What should I do to do a "fast boot flash boot"? Share this post Link to post Share on other sites
tooz 56 Posted May 30, 2022 Hello @hisataro, you can use the command: adb reboot fastboot Share this post Link to post Share on other sites
hisataro 0 Posted May 30, 2022 Thank you for your support > I ran "fast boot flash boot", but it said "Waiting for device" and couldn't proceed. I did adb reboot fastboot on another PC and it went on. Tinkerboard2 became the Recovery screen after booting. I don't know what to do on the Recovery screen. Share this post Link to post Share on other sites
tooz 56 Posted May 31, 2022 hello @hisataro, please try the following and see if the device can be found: fastboot devices if the device has been detected, you can try the reboot fastboot command otherwise, we'd suggest to re-flash the device 1 Share this post Link to post Share on other sites
hisataro 0 Posted May 31, 2022 Thank you for your support. @tooz "reboot fastboot" was succed. And the screen was changed to "Android Recovery". What should I do next to root TinkerBoard2? Share this post Link to post Share on other sites
tooz 56 Posted May 31, 2022 hello @hisataro, please continue follow the instruction, now you'll need execute this command adb push boot.img /storage/emulated/0/Download to flash the image 2. Copy the boot image to your device adb push boot.img /storage/emulated/0/Download/ 3. Download the latest version of Magisk Installation | Magisk (topjohnwu.github.io) 4. Install Magisk adb install Magisk.apk 5. Launch Magisk from your device 6. Press the Install button 7. Choose “Select and Patch a File” in method, and select the boot.img file, The Magisk app will patch the boot.img file to [Internal Storage]/Download/magisk_patched_[random_strings].img 8. Pull magisk_patched_[random_strings].img to your PC adb pull /storage/emulated/0/Download/magisk_patched_[random_strings].img 9. Flash boot image patched by magisk in fastboot mode adb reboot-bootloader fastboot flash boot magisk_patched_[random_strings].img fastboot reboot 1 Share this post Link to post Share on other sites
hisataro 0 Posted June 1, 2022 Thank you for your support. @tooz > 9. Flash boot image patched by magisk in fastboot mode > > adb reboot-bootloader After this, I couldn't find the device in [fastboot devices]. But, Apply the <Android Bootloader Interface> driver from your PC's Device Manager. I could see the devices in [fastboot devices]. > fastboot flash boot magisk_patched_[random_strings].img This also seems to be successful. > fastboot reboot This also seems to be successful. However, when TinkerBoard2 starts after this, the Android Recovery mode screen will be displayed. As I asked before, I don't know what to do in Android Recovery mode ...? Share this post Link to post Share on other sites
tooz 56 Posted June 1, 2022 hello @hisataro, thanks for the details. at this point, we would suggest to re-flash the device first: User Guide · TinkerBoard/TinkerBoard Wiki (github.com) once the flashing is done, please copy the boot image to the device. the boot.img file (TB2_Android11_v2.0.6_boot_img) is re-uploaded and can be downloaded here: https://www.asuswebstorage.com/navigate/a/#/s/50AF1C5364224C2BA8C8A5802DD779064 adb push boot.img /storage/emulated/0/Download/ then you can start rooting the device using magisk, please follow along the steps: 1 Share this post Link to post Share on other sites
hisataro 0 Posted June 7, 2022 Thank you for your support. @tooz > once the flashing is done, please copy the boot image to the device. the boot.img file (TB2_Android11_v2.0.6_boot_img) is re-uploaded and can be downloaded > here: https://www.asuswebstorage.com/navigate/a/#/s/50AF1C5364224C2BA8C8A5802DD779064 I created a patch from this image with Magisk and flashed it, and it succeeded in rooting! I used the "RootCheker" app to see if it was rooted. Thank you really!! Share this post Link to post Share on other sites
RichUK 0 Posted July 14, 2022 (edited) @tooz I'm using "Wireless debugging" do I need to use USB debugging??? I get to the same point .. after I run >> adb reboot-bootloader there are no fastboot devices connected? Edited July 14, 2022 by RichUK Share this post Link to post Share on other sites
RichUK 0 Posted July 14, 2022 SOLVED For others trying to follow this procedure @hisataro is correct I had ALL the exact same issues, it appears the boot.img (+20mb) in the original post doesn't work, use the one supplied by @hisataro in the post below (+30mb) and it works. On 6/7/2022 at 5:56 AM, hisataro said: > once the flashing is done, please copy the boot image to the device. the boot.img file (TB2_Android11_v2.0.6_boot_img) is re-uploaded and can be downloaded > here: https://www.asuswebstorage.com/navigate/a/#/s/50AF1C5364224C2BA8C8A5802DD779064 Share this post Link to post Share on other sites
RichUK 0 Posted July 14, 2022 Additional info: I also had to use adb via USB not Wireless and Windows 10 with fastboot a driver was required, Download from google and install .inf using exlorer, then via device manager on the usb device with issue choose update driver from list "Android phone" & "bootloader" https://developer.android.com/studio/run/win-usb https://beebom.com/fastboot-not-detecting-device-windows-10/ Share this post Link to post Share on other sites
hisataro 0 Posted February 22, 2023 boot.img は、Android11のソースコードをビルドする出来上がることを確認しています Share this post Link to post Share on other sites
tooz 56 Posted February 22, 2023 to compile boot.img: source build/envsetup.shlunch WW_Tinker_Board_2-userdebug./build.sh -CKA it'll be located in directory: rockdev/Image-WW_Tinker_Board_2/ 1 Share this post Link to post Share on other sites
michaelbhavel 0 Posted July 8, 2023 (edited) On 3/29/2022 at 11:36 AM, RichUK said: As the topic suggests, How do you root the Tinkerboard 2, either Andoroid 10 or 11 will do.. ? Is this forum dead? the activity is so low? To root Tinkerboard 2 running Android 10 or 11, you can follow these general steps: Unlock Bootloader: Before rooting, you usually need to unlock the bootloader of the device. The unlocking process may vary depending on the device. You can find specific instructions for unlocking Tinkerboard 2's bootloader. Install a custom recovery: After unlocking the bootloader, you will need to install a custom recovery like TWRP (Team One Recovery Project). Custom Recovery allows you to install root files. Flash the root package: Once the custom recovery is installed, you can flash the root package such as Magisk or SuperSU. These packages provide the necessary files to gain root access on the device. Please note that rooting a device may void its warranty and potentially cause problems if not done correctly. It is important to research and follow the trusted instructions specific to TinkerBoard 2 to ensure a successful root process. Regarding forum activity, it is possible that the forum you mentioned has low activity or is not the most active community for tinkerboard 2 discussions. You can try exploring other forums, online communities, or developer resources that focus on Tinkerboard 2 or Android development to find more active and helpful communities. If you have any problem or question about this you can contact me. I will be happy to help you. Source: https://theshadowapk.com/ Edited July 8, 2023 by michaelbhavel Info Add Share this post Link to post Share on other sites
Vincenzo Terracciano 0 Posted May 1, 2024 Is this procedure valid also for rooting tinkerboard S with androidN (Tinker_Board-AndroidN-V14.4.0.14-20200711)? Share this post Link to post Share on other sites
michaelbhavel 0 Posted September 24, 2024 @Vincenzo Terracciano Yes, procedure work for rooting the Tinkerboard S with AndroidN (Tinker_Board-AndroidN-V14.4.0.14-20200711). Share this post Link to post Share on other sites
michaelbhavel 0 Posted December 22, 2024 On 7/14/2022 at 3:08 PM, RichUK said: @tooz I'm using "Wireless debugging" do I need to use USB debugging??? I get to the same point .. after I run >> adb reboot-bootloader there are no fastboot devices connected? I think no, USB debugging not required if you're using Wireless Debugging. No fast-boot devices connected error typically means the device not in fastboot mode or is not detect. Ensure, it's in fastboot mode and try restart adb with adb kill-server and adb start-server. Share this post Link to post Share on other sites
Fantasy 0 Posted February 19, 2025 Hi @tooz, I want to root the Tinker Board 2/2S running Android 12 V3.0.2. Could you provide the boot.img for this version? Thank you. Share this post Link to post Share on other sites
tooz 56 Posted February 19, 2025 hello @Fantasy, you can download the boot.img of android v.3.0.2 here: https://www.asuswebstorage.com/navigate/a/#/s/C2F055F2E3A64D46BA7C63A4BF9F6D864 Share this post Link to post Share on other sites
