Jump to content
Pirate
Official 7" Pi Touchscreen doesnt work
Recommended Posts
The Raspbian official 7" touchscreen doesnt work on the 2S like it did on the TinkerBoard and S
/sys/class/backlight is empty
/sys/devices/platform/ff150000.i2c/i2c-3/3-0045/tinker_mcu_bl doesnt exist like it did on TinkerBoard
Share this post
Link to post
Share on other sites
root@linaro-alip:/sys/devices/platform# dmesg | grep ili9
[    2.017431] tinker-mcu: tinker_mcu_ili9881c_probe: address = 0x36
[    2.023535] tinker-mcu: tinker_mcu_ili9881c_probe: i2c_id= 0x8
[    2.075209] tinker-mcu: tinker_mcu_ili9881c_probe: init_cmd_check[-6] failed, 0
root@linaro-alip:/sys/devices/platform# dmesg | grep 5406
[    6.117044] tinker-ft5406: tinker_ft5406_probe: address = 0x38
[    6.122899] tinker-ft5406: tinker_ft5406_probe: touch is on DSI-0
[    6.638485] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
Share this post
Link to post
I connected RPi 7" display to Tinkerboard 2 through Waveshare cm-dsi adapter referenced above.  For both Android 10 and Android 11, I get the Tinkerboard splash screen on the Rpi display but do not get the Android splash screen.  Is there a configuration file I need to update?
Share this post
Link to post
Got it working with Android 11 by adding following line to /dtoverlay/config.txt:
overlay=DP_VOPB
Share this post
Link to post
hello @philc,
great to know that the board and the display are up and running, let us know if there's other issues.
Share this post
Link to post
I tried a dsi cable 15 to 22 pins but display remain blank.
Is there a way to switch CSI to DSI and connect the panel there? In case, will hdmi still be usable?
In config.txt Is mentioned thep anel-asus-DSI1-overlay file but It doesn't exist in userdata.
Many thanks
Share this post
Link to post
Hi @tooz
Thank you for repliyng.
I'm using official 2.1.6 Debian 10 image.
It came out that it was a cable issue, with a physical (15 to 22 pins) ,adapter the screen now works and I'm able to use rpi 7'' display.
By the way, the panel-asus-DSI1-overlay is not present in overlay folder. I still would like to use the CSI connector without the adapter. Would it be possible to attach rpi screen to the 15 pins CSI connector? What changes do I need to do in dts?
Many thanks.
Share this post
Link to post
hello @Fra189,
Quote
the dsi and csi interfaces are different and cannot be configured as such
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
